question about wiring up a tach.... - JeepForum.com
post #1 of 5 Old 03-03-2013, 07:53 PM Thread Starter
Jevy
Hey everyone,
I am wanting to put a tach on my CJ and have a couple questions. I have a 350 with electronic ignition. I've read quite a bit about wiring one up and understand the switched hot, ground, lights but not very clear on the wiring that actually monitors the rpm's of the engine. From what I've read I connect it to the coil but I'm not quite sure what this means as in where to connect it to. Can I get a little more info on where/how to do that terminal? I'm also thinking of going with a column mounted tach. Any opinions on that as well?
My '84 CJ7
Thread
My M416 with Roof Top Tent
Thread
Jevy is offline
post #2 of 5 Old 03-03-2013, 08:00 PM
78FordF150
1983 CJ7
On the top and side of your distributor cap is a square plug end with wires running to it. One of the spade terminals will be marked TAC. Run the wire from your tacomator to the TAC plug.
Measure with a Micrometer
Cutter with an ax
Beat it to fit
Paint it to match
My NP435 install
78FordF150 is offline
post #3 of 5 Old 03-03-2013, 08:01 PM
CSP
Assuming you're talking about an aftermarket tach and not a stock CJ tach, the green wire from the tach goes to the negative side of the coil or the tach terminal if you have a large cap HEI distributor.
CSP is offline
post #4 of 5 Old 03-03-2013, 08:07 PM Thread Starter
Jevy
I'm looking at some of the 5" auto meter tachs. I also failed to mention my 350 is carbureted and has electronic ignition. Thanks for the help guys I'll look at the distributor tomorrow to check for the wires as suggested.
My '84 CJ7
Thread
Thread
Jevy is offline
post #5 of 5 Old 03-03-2013, 08:40 PM
CSP
You mentioned the electronic ignition. Hookups are still the same as already described depending on what electronic ignition it has. If it's stock for the 350 it will be the HEI and have the tach terminal.
CSP is offline
