question about what tranny and transfer case i have - JeepForum.com
post #1 of 5 Old 04-13-2013, 05:33 PM Thread Starter
paff336
I aquired a 1978 cj7 that had a 258 inline 6 that was taken out by the po. Its an automatic and has fulltime 4wd with a knob in the glove box to lock something with the 4wd. It doesnt have locking hubs. Could anyone tell me what tranny and transfer case this is equipped with?
paff336 is offline
post #2 of 5 Old 04-13-2013, 05:38 PM
skizriz
1978 CJ7
A TH400 3 speed transmission, and a Borg Warner 1305 (1339 if you have low range) or simply called a Quadratrac, transfer case.
It's the same setup as I have.
skizriz is online now
post #3 of 5 Old 04-13-2013, 05:40 PM Thread Starter
paff336
Is the transfer case any good or is it something i should swap out
paff336 is offline
post #4 of 5 Old 04-13-2013, 06:05 PM
skizriz
1978 CJ7
The biggest negative with them is the the chain eventually stretches and needs replaced.
The good Morse chains are just about impossible to find, and will cost close to $400. (I do know of a place that has a few in stock for $375)
You can get a Chineese made chain, but the quality just isn't there. I had one stretch and become unusable after 4 hours. They are about $200.
Over all it pretty tough and will last if maintained, the biggest is running the proper oil. I trash mine fairly hard and other than replacing the chain (with 96,000 miles) it has taken everything in stride.
Here's some good reading on the Quadratrac.
http://jubileejeeps.org/quadratrac/index.htm
Here's the oil that goes in it. Anything else can ruin it.
http://www.bjsoffroad.com/prod-76.htm
post #5 of 5 Old 05-02-2013, 12:36 PM
patrickpat
1977 CJ7
Both TH400 an QT are real tough when maintained check oil once a year and replace TLC1 when you hear no ratteling keep chain unbothered, you can check chain for strech...you've got a real Jeep here..permanent 4by4!!
patrickpat is offline
