Question about Warn Replacement Hubs - JeepForum.com
post #1 of 3 Old 03-21-2013, 09:37 AM Thread Starter
NoNative
My factory lock out hubs are due to be replaced and I want to see if these "Standard" Warn lock out hubs will fit under the factory center caps. I've read where the "premium" Warn hubs will not fit under the center caps.
Thanks for the help!
http://www.quadratec.com/products/26103_02.htm
1986 CJ-7 Laredo, 258, AX15, AC Dana 30/44, Ox Lockers, Howell TBI, DUI, 4.5" RE YJ Springs, 1.25" BL, clocked & twin-sticked Dana 300 with Lomax 4-1, 4.10s, 33s, PB, 8000# winch, YJ Roll Bar, Factory 20 gallon tank.
1984 CJ-7 Renegade, 258, T4, AC, Howell TBI, DUI, 2.5" OME YJ Springs, 3.53, 31s, PB, Warn bumpers & 8000# winch, Factory 20 gallon tank
1984 CJ-7 Renegade, 258, Auto, AC, 3.31s, PB, Factory 20 gallon tank, Bone stock except for 31s
NoNative is offline
post #2 of 3 Old 03-21-2013, 10:55 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
those are basically what was OEM on your jeep. Having both sets handy (5 bolts, not 6) they are the same diameter and have the same gap around them to the centers of my cragars.
If your old ones fit under your center caps then these will as well.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #3 of 3 Old 03-21-2013, 11:14 AM Thread Starter
NoNative
Good stuff. I'll order them up and report back to confirm or deny that they fit under the center caps. They appear to be the same size.
NoNative is offline
