Hello and thank you for the help.
I recently failed my smog test here in Cali for bad timing (among other things).
I am trying to find out what the correct setting is suppose to be. It seems to me that my Haynes manual skips my year, but when I do set it I must set my rpm at 1600.
I have a timing light. I do not have a tach, I thought about installing one but my current gauges only work half the time and when they work they are half wrong.
My timing light has a built in tach for that job. Tune up kits come with clip on tachs. You must have one or you will just fail again. The engine is really picky about timing.
Same for setting up things like the choke's fast idle, a tach is needed to get it right.
There is an advance plate under the distributor cap that can get seized up because folks don't know you have to oil the felt pad under the rotor every tune up. To test, remove distributor cap and see if you can hand turn the rotor. It should be under strong spring load and snap back fast.
The tuneup specs for the Calf. models might be different than the other states. You should have a sticker on the grill near the radiator that tells you what to set everything to.
Thanks for all the help.
I think I have the timing straightened out but I still failed my smog test. I went from barely a polluter ( I failed my NO by 12 ppm) to a gross polluter.
Smog Nazis
Y'all oughta move to Texas. CJs are all emissions exempt now, :2thumbsup:
I had a few extra parts after my last tune up I did. I can put all that junk in a cardboard box n' mail it to you if it'll help.
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
