question about gears - JeepForum.com
post #1 of 4 Old 07-10-2011, 10:06 AM Thread Starter
ymurf
1979 CJ7
I have a 79 cj7 with stock amc20 rear and dana30 front end.Jeep has 3 speed manual in it.How would I know what gears I have od do any of you guys know what would have came out with this set up? I am going to be putting an ax15 5 speed out of a YJ and want to know if my gears will be ok going to a 5 speed?
ymurf is offline
post #2 of 4 Old 07-10-2011, 10:14 AM
billybob535
Your desired tire size is needed to determine what gears would be correct for you.
billybob535 is offline
post #3 of 4 Old 07-10-2011, 10:18 AM Thread Starter
ymurf
1979 CJ7
It has 31/10.50/15 on it..I am swapping out the 258 for the FI 4.0 and 5 speed with a Dana 300 ts.
ymurf is offline
post #4 of 4 Old 07-10-2011, 10:24 AM
gojeepin
1983 CJ7
Your old transmission's 3rd gear is 1:1 and the AX-15's 4th gear is 1:1. The 5th gear will be to only one that's different and it's .79:1.
As for your axle ratios, you could check the tag/stamp on them, if they're still there.
You could also spin a wheel and count the revolutions of the driveshaft.
- One wheel off the ground: spin it two revolutions.
- Both wheels off the ground spinnin the same direction: spin one revolution.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
Gears and tire size question davefreeman Jeep CJ Forum 11 03-20-2010 11:40 PM
T18 Tranny Swap/Swapping Gears Over to Mainshaft Question connor014 Jeep CJ Forum 3 03-11-2010 01:20 PM
ugrading gears question 00bluedak Jeep CJ Forum 2 11-06-2009 02:43 AM
Question on chaning timing gears crawdad Jeep CJ Forum 1 03-22-2009 01:33 PM
Gears Question cj shark Jeep CJ Forum 4 04-25-2007 03:22 PM
