Question about fuel lines 77 CJ7 - JeepForum.com
post #1 of 4 Old 04-09-2012, 09:05 PM Thread Starter
rns59
Ok...on my 77 CJ7 I've got 2 lines coming from the top of my fuel tank. One is the fuel line...not sure about the other one unless it's the return line. If so...where does it hook on the carburetor? Can anyone help? Thanks!
rns59 is offline
post #2 of 4 Old 04-09-2012, 09:30 PM
CJinDNA
1979 CJ7
Return line would actually hook up to the bypass style fuel filter depending on engine/carb combination. Return line should be run down the driver's side of the frame. Image of the bypass type filter - http://www.jeep4x4center.com/fuel-fi...3-8129383.html
CJinDNA is offline
post #3 of 4 Old 04-16-2012, 10:35 PM
Jeepkid1995
1979 CJ7
Just did this on my '79 CJ7 today, and it uses the same style fuel filter as the one in CJinDNA's link above. The fuel line down the right side of the vehicle goes over top of the valve cover (assuming you have the stock 258) and plugs into the side of the filter with the single plug. The return line on the left side of the vehicle plugs in to the smaller of the two plugs on the other side of the filter, and the larger plug runs right into the carb. If I remember mine right now, there is a large obvious plug on the front of the carb.
Hope this helps, and wasn't too confusing
Jeepkid1995 is offline
post #4 of 4 Old 04-17-2012, 01:00 AM
BagusJeep
1981 CJ7
some images. The trick with the filter is to mount it horizontally and have the tank return at 12 o'clock. The diagram maks it look like it is alongside but this is a fault with the sketch.
worth checking which tank you have. The sketch below is for the later 1980s set up with the tank vent running to a canister in the engine bay. Yours probably has a fuel line and a return line and a vented filler cap.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
Question about replacing fuel lines wingedmare Jeep CJ Forum 6 05-23-2012 07:44 PM
Fuel Lines Pirate40 Jeep CJ Forum 3 03-11-2012 08:27 PM
Best way to clean the fuel tank and fuel lines? Ryan546 Jeep CJ Forum 14 06-19-2011 08:29 PM
Installing Fuel Tank and Fuel Lines? How Hard? JeepFan07 Jeep CJ Forum 6 01-10-2008 06:49 PM
Weber 34 conv, nutter, Vacuum lines / Fuel lines valkadesh Jeep CJ Forum 29 06-11-2007 09:21 AM
