Question about fabrication with tubing - JeepForum.com
post #1 of 10 Old 10-15-2013, 10:54 AM Thread Starter
redsduty
1978 CJ7
I have been building some custom side steps with rectangular tubing and making modifications to the factory sport/roll bar. The tubing ends will all be capped and welded closed. Will a closed, sealed tube cause rust from the inside out due to moisture/condensation, or should I drill a weep hole to let moisture/condensation out?
I can see it both ways. I'm leaning towards leaving a weep hole at a low point.
Maybe this should be in the fab. section but there is always good input here.
Thanks.
redsduty is offline
post #2 of 10 Old 10-15-2013, 11:38 AM
texasdave
texasdave's Avatar
1980 CJ7
You could coat the inside of the tube. Or you could drill a small hoe and tap it to put a plug in and then check to see if you have moisture.
texasdave is offline
post #3 of 10 Old 10-15-2013, 12:16 PM
CSP
There's only going to be so much moisture inside your capped tube. If you get it good and warm just before welding there will be almost none. It would take many, many years for that little bit of moisture to do any noticable damage to the relatively thick wall of the tube.
With a weep hole there will ALWAYS be moisture in the tube.
This is something I never even would consider living where I live.
CSP is offline
post #4 of 10 Old 10-15-2013, 05:10 PM
danielbuck
1946 CJ2
I would think the welding alone would be enough heat to get rid of any moisture inside.
But either way, so long as it's not got water sloshing around inside of it when you cap it up, it's probably not enough to do anything more than minor surface rust?
danielbuck is offline
post #5 of 10 Old 10-15-2013, 05:16 PM Thread Starter
redsduty
1978 CJ7
Thanks for the input. I like the drill and tap a hole idea. Warm the steel before capping t0 minimize moisture is also a good thought.
While modifying my sport/roll bar I noticed abut a 3/16" hole in the main hoop where the angled back bars connected along with a hole on the bottom of each rear mounting foot. I guess I thought there was some kind of magic reason for the holes. Moisture was the only thing I could think of or maybe it was for wiring of some sort.
redsduty is offline
post #6 of 10 Old 10-15-2013, 05:29 PM
skizriz
1978 CJ7
Drill a small hole in it, dump some paint in there, roll it around, let it dry, weld hole shut.
skizriz is offline
post #7 of 10 Old 10-16-2013, 08:44 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I would just weld it closed and be done with it. Unless water gets in thru a "pinhole" somewhere, the tube would take a lifetime to rust from the inside out. If really worried about it, shoot some "Cold Galvanizing Compound" or "Weld-Thru Primer" into the tube before closing it off. Really not necessary though IMO. A threaded plug is just someplace for water to seep in.
As a comparison.. my shop air compressor was made in 1971.. it sits around with moisture in the tank.. and still holds 175psi. No rust thru yet.
BESRK is offline
post #8 of 10 Old 10-16-2013, 06:19 PM Thread Starter
redsduty
1978 CJ7
Thanks for the input. I'll seal them up and not worry about it.
redsduty is offline
post #9 of 10 Old 10-16-2013, 06:35 PM
danielbuck
1946 CJ2
if it's still bothering you and you wanted peace of mind, you could take a heat gun or a torch and shoot it through the pipe for a bit before welding the caps on.
post #10 of 10 Old 10-16-2013, 08:02 PM
dtcohen
1980 CJ7
I wouldn't worry about it. Think about the tank on an air compressor. They get all kinds of moisture in them and rarely rust out.
dtcohen is offline
