question about driving in third gear. - JeepForum.com
post #1 of 11 Old 06-24-2012, 04:10 PM Thread Starter
jamesc59
1959 CJ5
been having a problem when in third gear, after i shift into third gear about maybe a minute in my cj-5 will just start shaking violently, scares the crap out of me everytime, im fairly new to driving stick, so im not to sure if im just not going the correct speed when shifting or ive heard that may be u-joints? anybody have any ideas what may be the cause or anybody with any experience with this?
jamesc59 is offline
post #2 of 11 Old 06-24-2012, 04:43 PM
86cj74.2L
86cj74.2L's Avatar
What mph and rpm are you at when it does this?
86cj74.2L is offline
post #3 of 11 Old 06-24-2012, 04:45 PM
hopefulcj76
1980 CJ7
Does this only happen in 3rd gear? Do you feel any vibrations in first when you are just getting the jeep move?
hopefulcj76 is offline
post #4 of 11 Old 06-24-2012, 04:51 PM
NExOBLIVISCARIS
1970 CJ5
only time my cj5 starts shaking violently is when i put it in reverse and it only shakes until the clutch is fully engaged. are you shifting when the engine starts to lug?
Jeepy (G-P) 1970 CJ-5 Renegade I, t86 with warn overdrive with a dana 18 , 4.88 rear end and a auburn pro series limited slip.
NExOBLIVISCARIS is offline
post #5 of 11 Old 06-24-2012, 05:03 PM
hopefulcj76
1980 CJ7
Mine shifted violently in first gear on the beach when the engine started to lug, it was bad, I thought that the drivetrain was going to explode at times. I replaced the engine mounts with the daystars and changed out the t-case/tranny as well. All is fixed. It's a pain, but it's worth it.
post #6 of 11 Old 06-24-2012, 05:11 PM
86cj74.2L
86cj74.2L's Avatar
Are you lugging it? As in trying to drive in 3rd gear. Just off idle
post #7 of 11 Old 06-24-2012, 09:37 PM
titomars
1981 CJ7
3rd gear is also right about death wobble speed. Are you sure it's trans related and not just speed related? If this happens only at a certain speed whether you are in 3rd, 4th or neutral you probably have death wobble. Which is a worn out front suspension system. It's not u-joints. They would have to be so bad you would hear the creeking and popping when ever the Jeep moves.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #8 of 11 Old 06-24-2012, 09:50 PM
BagusJeep
1981 CJ7
You could be at too low an engine speed or accelerating too agressively at a low engine speed. The vibration this sets up will be amplified by all the above sources.
You need to check the gearbox and engine mounts for play, the U joints for play and the suspension at both ends as well as wheel bearings.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #9 of 11 Old 06-24-2012, 10:28 PM
phritz
1983 CJ7
Your profile says you have a 1959 CJ-5 with a 4 cylinder and 3 speed t 90 transmission pushing 33" tires. So....there are lots of things that could be wrong. The steering system on older Jeeps has lots of extra moving parts compared to the more "modern" 1972 and up Jeeps. If you don't know where the bellcrank on your Jeep is (and yes you have one ), it's time for you to find a picture of you Jeep's steering system. The bellcrank itself has three wear areas. The link between the base of the steering column and the bellcrank has two wear points. Then you have the drag link and the tie rod, with all of their associated ends. Your front axle is either a Dana 25 or Dana 27, which have knuckle bearings instead of ball joints. All of these are places to look for wear and play. Poorly balanced tires could also be your problem.
A good start would be to have someone sit in the Jeep without the engine running and slowly rock the steering wheel back and forth while you look at all of the steering system looking for play or looseness in any of the joints.
My first Jeep was a 1953 M38A1, your Jeep's military Dad. Bought it in 1974 as a "project". It had the same steering set up. It was a frame up, so I replaced everything.
Good Luck !!
phritz is offline
post #10 of 11 Old 06-24-2012, 10:33 PM
Skerr
Next time it starts to do that, downshift to second. Offhand, it sounds like you're driving at too slow speed in third gear. The engine is trying to stall. OR- it's one of the other things posted above!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #11 of 11 Old 07-03-2012, 02:28 AM Thread Starter
jamesc59
1959 CJ5
yeah im pretty sure it was just that i was driving at too low of a speed and i dont have a tachometer on it so im still getting used to having to listen to the engine! coming from a 2wd dodge ram its a big step up im glad to finally be part of the jeep community!
jamesc59 is offline
cj-5 , gears , jeep , willys
Wheels Question and gear question Kaorder22 Jeep CJ Forum 7 03-28-2012 06:29 AM
Hey all, question about daily driving a CJ? vtjeepvt Jeep CJ Forum 14 12-22-2010 02:27 AM
4th Gear Noise (supposed to be driving up North Friday) VanFaasenC Jeep CJ Forum 18 08-19-2010 05:37 AM
gear question? NVRDUN Jeep CJ Forum 3 04-28-2009 11:24 AM
Another gear question DZLCJ7 Jeep CJ Forum 2 07-24-2004 07:01 PM
