question about axle gearing - JeepForum.com
post #1 of 9 Old 01-08-2010, 03:21 AM Thread Starter
Chuckles0227
1980 CJ5
i have 31's and stock 3.08's in my d30 and amc 20. I was wondering if i need to re-gear at all. I really do not know much about gearing, and i know that there are plenty of experts in the subject on this forum. I also know for a fact that i'm missing one tooth, and a few are shaved on my d30 ring gear.
as always, thanks for the help
Brent
Chuckles0227 is offline
post #2 of 9 Old 01-08-2010, 03:25 AM
VanBCguy
I ran a D30 front and D35 rear with stock 3.07 gearing for many wheeling trips. Take care of it, be light on the skinny peddle and you should be fine. You could regear better of course, but what you have is adequate and highly useful. It depends greatly on your driving habits and wheeling habits. I would look after whatever you know needs fixing/replacing though.
VanBCguy is offline
post #3 of 9 Old 01-08-2010, 07:16 AM
78treehugger
1980 CJ7
Regearing is a preference. Whatever you do fix the dana 30 gears. That will not last. Gearing also depends on what driveline you have and what your intended purpose is with you jeep. Hardcore offroading will require lower gears. More of a streetable jeep you shuold be fine.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #4 of 9 Old 01-08-2010, 09:14 AM
80cj
80cj's Avatar
1980 CJ5
Brent
You should fix the D30. While you're at it, you might consider a gear ratio change if you're looking for better performance. My 80 CJ-5 came with the optional (for 1980) 3.54 gears and that ratio seemed to go well with 31 inch tires and it still got decent gas mileage. 3.54 is the highest numerical ratio you can go to without changing your D30 carrier.
80cj is offline
post #5 of 9 Old 01-08-2010, 11:13 AM
jumbojeepman
1976 CJ7
3.08 seem kinda low (numerically) for 31" tires. I would think you want at least 3.54's (stock on my 76 CJ-7.)
jumbojeepman is offline
post #6 of 9 Old 01-08-2010, 11:58 AM
DT5150
1983 CJ7
imo, you can get by just fine with your current ratio with 31" tires. but i'd be fixing the broken stuff for sure.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #7 of 9 Old 01-08-2010, 01:17 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
My 80 has the 3.08 gears and 31"BFG MT. i can run 85MPH down the highway and get me down any trail or through any mud i have treid. No rockcrawling here. What do you want to do with the Jeep is the queastion?
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #8 of 9 Old 01-08-2010, 02:19 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
This is basically how I feel about it, as well. However, (to the OP) you'r going to need to spend the money on a gear setup regardless if whether you fix your problem or select another ratio. This is the time to ask yourself whether you see your vehicle's tire size growing in the future. If you think you will jump to 33's (and still run a 4-speed), you may want to consider a ratio change to something in the 3.73 area.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #9 of 9 Old 01-09-2010, 02:46 AM Thread Starter
Chuckles0227
1980 CJ5
thanks for all the input guys. If i were to change the ratio to 3.54 would it benefit me much as a dd, with casual wheeling? also the front dif seems to be fine even with the missing tooth, i didn't actually see a broken tooth it's just that when i took the cover off and cleaned out the muck i found about a 1 inch piece of metal that looked like a tooth to me, with some metal shaving. As of right now im really going for as much gas mileage as i can get. im currently getting 12-13mpg running 89 and 10 with 87, i also know that im running a bit rich, but that's a completely different issue
cheers,
Brent
Axle gearing canuck2a Jeep CJ Forum 2 03-17-2009 07:32 AM
Gearing Question CompGuru Jeep CJ Forum 2 01-03-2008 02:09 AM
T18A & Dana 20 rear axle gearing Bard Jeep CJ Forum 1 09-24-2006 05:06 PM
Gearing Question? blackdog Jeep CJ Forum 2 01-22-2006 10:48 PM
CJ7 axle, gearing, locker questions DaRaidz Jeep CJ Forum 2 02-28-2003 09:45 PM
