A question about 258 Intakes and Carb Upgrades - JeepForum.com
post #1 of 5 Old 11-05-2009, 10:01 AM Thread Starter
78CJFIVE
1978 CJ5
If your Jeep has the Carter 1BBL does that mean that your Intake can only accept 1BBL Carbs?
Is it possible that the Jeep has a 2BBL Intake with a Carter 1BBL? If yes, how common is this, and what is the easiest way to know?
I would like to upgrade my Carter 1BBL to ether the MC2100 or a Weber. If I have a 1BBL Intake, I know that I can ether get a new Intake, or an adapter plate.
I know the plate would be cheaper route. What are the advantages (besides cost obviously) / disadvantages to the adapter plate?
78CJFIVE is offline
post #2 of 5 Old 11-05-2009, 10:59 AM
Pathkiller
1974 CJ5
Yes. Unless you get an adapter to put a 2bbl carb on your 1bbl intake.
Possible, but highly unlikely. It wouldn't be a factory setup, but some previous owner might have done this for god know's what reason.
I would like to upgrade my Carter 1BBL to ether the MC2100 or a Weber. If I have a 1BBL Intake, I know that I can ether get a new Intake, or an adapter plate. Yes.
Advantages: Cost. Can't think of any others.
Disadvantages: Not getting full performance potential from your new 2bbl carb by restricting it via a 1bbl manifold. Essentially this is like a NASCAR restricter plate. The new 2bbl will still give you better performance than your old YF, but not as much as you could potentially get by using a proper 2bbl manifold. Or even an aftermarket 4bbl manifold with a 2bbl adapter.
Pathkiller is offline
post #3 of 5 Old 11-05-2009, 11:45 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Might even need two adapters. "Large 2bbl to small 2bbl" and then a "small 2 bbl to 1 bbl adapter". lots of places for leaks.
You could always get a 1bbl off a Ford F-150 with a 300 cuin engine, That's a big YF 1bbl.
Best though with a 2 bbl manigold.
There are two 2bbl manifolds also. On water heasted and one were the exhaust bolts to the intake. The water cooled one would be better.
John Strenk is offline
post #4 of 5 Old 11-05-2009, 06:58 PM
MikeMCJ
1951 M-38
I think you need a cast iron 2bbl, not the aluminum ones used on later 4.2s, to work (properly) with your exhaust manifold. I've been looking for one as well. I think casting #8126521 will work, but I know there are others. Maybe someone with a cast iron 2bbl can post their intake casting #?
MikeMCJ is offline
post #5 of 5 Old 11-05-2009, 07:39 PM
bas157
1980 CJ7
MikeMCJ, I've got a cast iron 2 brl one laying around (well its my brothers but its laying around my house) that has a few numbers on it. How do you know which is the casting number? Does 3227135 sound like a casting number? It looks like the kind you posted a picture of.
bas157 is offline
Timing question & adjusting carb question. jatepper Jeep CJ Forum 8 02-22-2009 08:29 PM
304 intake and carb upgrades hold24 Jeep CJ Forum 4 01-27-2009 06:24 AM
76 CJ7 304 Carb Question tyler_stephen Jeep CJ Forum 7 02-18-2008 08:25 PM
258 intakes petey156 Jeep CJ Forum 5 11-21-2005 03:38 AM
'73 CJ-5 Carb Question xtstgrt Jeep CJ Forum 3 02-15-2004 02:09 PM
