Quadratrac problems - JeepForum.com
post #1 of 10 Old 10-18-2009, 11:35 AM Thread Starter
michel1972
1993 XJ Cherokee
Quadratrac problems
Hello,
I am the happy owner of a cj8 scrambler with a LS6 big block in it. I have the car for 1 month now but i am having problems with the quadratrac. For street use i dont have any problems but when i am driving offroad my quadratrac can not handle the power.
I have a front dana 44 axle with passengerside offset and a 9 inch rear axle also with a passengerside offset. The previous owner spend a lot off money on these axles so changing these axles is not that easy.
What can i do? Is it possible too buy a dana 300 transfercase and still use my offset rear axle? Or must i buy a dana 18 transfercase but will a dana 18 transfercase be a better solution instead off the quadratrac transfercase.
All suggestions are welcome.
michel1972 is offline
post #2 of 10 Old 10-18-2009, 01:20 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You need to explain the actual issue. Is the chain jumping? this is a common problem and is easily fixed by replacing the chain. Are you engaging the emergency drive? If you don't, the front won't positively lock up with the rear and slippage can occur from a single tire. There are also part time kits available if you don't like the full time feature.
jeepdaddy2000 is offline
post #3 of 10 Old 10-18-2009, 02:24 PM Thread Starter
michel1972
1993 XJ Cherokee
The problem is that the chain is jumping. The previous owner and me changed the chain 3 times the last 6 months. The chain keeps ok onroad but when going offroad for the problems start again and the chain begins jumping. The previous owner also replaced the quadratrac because it was smacked too pieces. I know this cj8 has a big engine with very much power. Could that cause the problems? The engine is producing 450 bhp. Could the quadratrac handle that much power.
I have the ermgency drive but when i hit the throttle than the problems start and the previous owner destroyed his quadratrac when he engaged the emergency drive. It seems like too much horsepower than the emergency drive can handle.
post #4 of 10 Old 10-18-2009, 07:48 PM
jeepdaddy2000
1971 CJ5
The q trac is a good case. While the 401 is a big engine, the t case should handle it fine. The fact the chain has been repeatedly changed smacks of another problem. I would inspect the sprocket bearings and the splines on the transmission output shaft/t case input.
Might also insure the splines on the drivelines aren't slipping as well. You can do this by locking up the wheels with the brakes and loading the drivetrain till something gives. Observe the drivelines. If you see either the front or rear yoke rotate then you have found your problem.
If you see either driveline turn, then that axle has a hub slipping.
Bear in mind that repeated heavy abuse of any component will eventually cause it to fail.
You can replace the t case with a D18 from an early CJ, however, the adapters can be kind of spendy. Try the Novak website for more adapter info.
post #5 of 10 Old 10-19-2009, 03:28 AM Thread Starter
michel1972
1993 XJ Cherokee
Thanx for your help! I will check the shafts and bearings. I was also thinking about buying a mile marker too convert it from 4x4 too 2x4. The problem is that the price for a mile marker here in Europe is expensive. Buying a mile marker in the USA and transport it too Europe an paying 25% taxes will cost me around 1000 dollar. A dana 18 with converter will cost me around 1450 dollar here in Europe. So i think it is maybe better too replace the quadratrac for a dana 18 or not ???
If i buy a dana 300 will it work with my offset 9 inch rear axle?
post #6 of 10 Old 10-19-2009, 05:35 AM
gojeepin
1983 CJ7
Originally Posted by michel1972 View Post
Hello,
While the shafts/bearings may have caused the original problem, and still may be the source of the problem, check the teeth on the sprockets themselves. They will become rounded if the chain slips (or multiple chains slip) over them much.
Possibly, but that will introduce other issues since it doesn't differentiate between front and rear axle like the quadratrac. Here's a good explanation of what you may be getting into.
http://www.jpmagazine.com/techarticl...ase/index.html
...If i buy a dana 300 will it work with my offset 9 inch rear axle?
The sideways deflection angle on your driveshaft would be quite a bit. That, coupled with the deflection angle for any lift would make using your offset 9" axle very problematic.
That being said, you could make it work with a CV joint on both ends of the driveshaft but I don't think I'd do it.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #7 of 10 Old 10-19-2009, 06:08 AM
ElZorro
Nope. The 300 output is centered, not offset like the dana 18 and quadratrac.
ElZorro is offline
post #8 of 10 Old 10-19-2009, 07:21 AM
fuzz401
1978 CJ7
Quadr track pictures by fuzzgremlin - Photobucket
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #9 of 10 Old 10-19-2009, 06:39 PM
John N
1981 CJ8
Don't let having to switch the rear axle keep you from using a Dana 300. Find a cenetered 9" and swap your center section into into it and move on. Still a cost, but better than using inferior parts.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #10 of 10 Old 10-20-2009, 12:05 AM
gojeepin
1983 CJ7
Just like John^^^... For simplicity's sake later on, if I were doing it I'd switch to the Dana 300 and a centered axle... Ford 9", Ford 8.8", Dana 44, etc.
gojeepin is offline
QuadraTrac Emergency Drive Shift Valve and QuadraTrac Lever Info? LiftforPleasure Jeep CJ Forum 20 02-21-2014 03:33 PM
Quadratrac problems still... peanutfarmer101 Jeep CJ Forum 3 07-31-2008 08:39 PM
quadratrac kw89425 Jeep CJ Forum 1 07-06-2008 04:19 PM
How do I know if I have Quadratrac in a 79 Cj7? tvtoez Jeep CJ Forum 1 02-18-2008 09:41 PM
quadratrac jepthng1 Jeep CJ Forum 1 06-15-2002 05:58 PM
