QuadraTrac Emergency Drive Shift Valve and QuadraTrac Lever Info? - JeepForum.com
post #1 of 21 Old 11-25-2008, 10:47 AM Thread Starter
LiftforPleasure
1976 CJ7
So, from all I can tell, the quadratrac has no shifter, tho i've been told different things about all this, that i can believe. my valve has no vacuum going to it and no switch in the glove compartment (like i've been told there should be) for the reason i believe to be cause someone dropped an 85 body on my 76/77 cj7.
but i'm curious......cause there's a lever on the driver upper side of the xfer that can be moved when the wheels are off the ground. and i'm curious as to verify what selection it should be in and that the xfer is working like it should etc
any info on this type of xfer would be appreciated!
LiftforPleasure is offline
post #2 of 21 Old 11-25-2008, 01:47 PM
illinicj
1979 CJ7
The low range unit, if you have one, is a cylindrical case bolted to the back of the transfer case. Not all qtrac had a low range unit. There is a shifter on it that is in neutral in the middle, high to one side, low to the other. I don't remember which is which, but you will know if you are in low gear. I also lack a shift mechanism due to a body swap, but there should be one near the driver seat to go from H-N-L. The vacuum shifter in the glove box switches from normal to "emergency" drive. In other words, full time 4wd to part time 4wd. You can usually find a used one on ebay. It routes vacuum to one side or the other of the vacuum motor, depending on the switch position, on the back passenger side of the case.
illinicj is offline
post #3 of 21 Old 11-25-2008, 05:28 PM
fuzz401
1978 CJ7
http://smg.photobucket.com/albums/v1...Quadr%20track/
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #4 of 21 Old 11-25-2008, 10:59 PM Thread Starter
LiftforPleasure
1976 CJ7
well i'd say this is all quite helpful! thanks! yeah i'll need all that for sure. i'm def have the low unit and need shift linkage and a emergency switch. plus my valve has a hole on the bottom end of it. and where did this indicator switch go to? some type of light?
i'm worried tho, i'm sure the chain is loose, it clunks every time i shift and/or let off the gas and get back on it.
post #5 of 21 Old 11-26-2008, 07:44 AM
j33pman
L- Forward
N- middle
H- Back
Bill H. - 1984 CJ-7
Now with Fiberglass!
j33pman is offline
post #6 of 21 Old 11-26-2008, 07:52 AM
martyweir
1976 CJ7
I have a Quadratrac, and when I turn the emergency switch in the G-box, I don't notice any difference in performance. I have read that the diaphram could be shot. How do I tell if I'm in E-drive or normal - Is there a way to tell from the emergency drive indicator switch shown on that diagram?
martyweir is offline
post #7 of 21 Old 11-26-2008, 03:41 PM
illinicj
1979 CJ7
The indicator switch on the case grounds the "emergency drive" light on the speedo cluster to let you know you are in 4x4. Even if your light/wiring is not working, you could switch back and forth and see if you get continuity between the switch terminal and ground in one position and not the other. You can also use a vacuum pump, syringe, or even your mouth to create a vacuum on the motor and see if it shifts/holds a vacuum.
illinicj is offline
post #8 of 21 Old 11-26-2008, 06:19 PM
BigTDog
If you can't find what you need on ebay let me know. I have a Q-trac in a donor CJ I would part with.
BigTDog is offline
post #9 of 21 Old 02-09-2010, 03:19 AM
Jeremy_C
1978 CJ7
I cant tell a difference either, are there two lines running from the switch to the engine? After doing a motor swap I have to small hoses coming from the heatbox glove box area. I haven't traced them yet.
1978 Cj7 360, Yellow.
Yellow Jeep Club member # 1982
Tennessee Vol Jeep Club # 1
Jeremy_C is offline
post #10 of 21 Old 02-09-2010, 07:05 AM
fuzz401
1978 CJ7
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #11 of 21 Old 02-09-2010, 08:03 AM
danheit
danheit's Avatar
1979 CJ7
I also have another full setup. Let me know if one of you guys need something. Also, here is a great source of info on Quadratrac systems: Jeep QuadraTrac
I NEED A SINGLE 15X8 MICKEY THOMPSON OR SIMILAR ALUMINUM BULLET HOLE WHEEL!!!!
Build Thread: 1979 CJ7
danheit is offline
post #12 of 21 Old 02-09-2010, 01:29 PM
Jeremy_C
1978 CJ7
Thanks for the pictures, what exactly does emergency drive do?
Jeremy_C is offline
post #13 of 21 Old 02-09-2010, 02:12 PM
CSP
Emergency drive eliminates the slippage that occurs within the transfer case. This slippage is what allows it to be a fulltime 4WD tcase.
The emergency drives essentially locks the front and rear driveshafts together so that equal power goes to both axles. It's then behaving like a transfer case would on a vehicle that has a part time tcase when shifted out of 2WD and into 4WD.
CSP is offline
post #14 of 21 Old 02-03-2011, 09:31 AM
Chapa
Good day, do you know where is this shifter located in a Wagoneer??
Thank you!
Chapa is offline
post #15 of 21 Old 02-03-2011, 09:44 AM
BioTex
1979 CJ7
Thank you!
On the transmission tunnel just in front of the drivers seat.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
Quadratrac low range linkage and shift lever. PIPER-68 Jeep CJ Forum 15 02-16-2013 01:46 PM
Quadratrac emergency mode question spokanecj7 Jeep CJ Forum 15 07-09-2010 12:07 PM
quadratrac emergency drive meatloaf Jeep CJ Forum 7 03-21-2008 04:16 PM
CJ7 Quadratrac Emergency Switch maback Jeep CJ Forum 8 05-05-2007 10:16 AM
quadratrac info needed high51977 Jeep CJ Forum 6 01-26-2007 08:02 PM
