Quadratrac - JeepForum.com
post #1 of 9 Old 12-25-2003, 08:56 AM Thread Starter
CJ7 Ditze
CJ7 Ditze's Avatar
Quadratrac
Hello,
merry christmas from Germany,
how many Quadratrac's would build in 78/79 ?
bye
Ditze
CJ7 Ditze is offline
post #2 of 9 Old 12-26-2003, 07:34 AM
Brock
Brock's Avatar
Every automatice in 78/79 was a quadratrac. I don't know how many, but many of the 73-79 Wagoneers also had quadratrac.
Brock is offline
post #3 of 9 Old 12-27-2003, 08:57 AM
Ruskie
Ruskie's Avatar
My 76' cj7 is a quad.
Ruskie is offline
post #4 of 9 Old 12-28-2003, 05:48 AM Thread Starter
CJ7 Ditze
CJ7 Ditze's Avatar
Quadratrac since 76?
post #5 of 9 Old 12-28-2003, 08:30 AM
wm69
All jeeps with automatic trannys made from 76 to 79 were quadratracs. They went to a dana 300 tcase in 1980
wm69 is offline
post #6 of 9 Old 12-28-2003, 09:26 AM
Ruskie
Ruskie's Avatar
Howdy, WM,
I'm new to the jeep scene. On my 76 CJ w/ quadratrack I've got a switch on the dash to the left of the steering wheel. The guy I bought the jeep from said that if I turn the switch to the right it will lock up the front and back axles to turn at a one to one ratio.
Do you know what this is called so I can research it and learn about it?
Thanks ahead of time for (if) answering my (probably) dumb question
Ruskie is offline
post #7 of 9 Old 12-28-2003, 11:17 AM
Popol
Popol's Avatar
Originally Posted by Ruskie
Howdy, WM,
Thats Quadratrac.
basically, it locks the wheels into 1.1 wheel ratio.
My 79 CJ is permanent 4 wheel, but in the sticky stuff, occasionally the wheels spin, thats when the quadratrac coms in, turn in on, get out of sticky stuff, turn it off.
Quadratrac si a great tool, but YOU MUST only use it when you wheels are slipping, it can damge the gearbox if you use it in normal driving, use it only when traction is being lost at the wheels.
1979 Jeep CJ7 5.0 V8 Auto.
300,105 original miles
well, maybe a few more now ;)
Popol is offline
post #8 of 9 Old 12-28-2003, 10:31 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Howdy, WM,
Full time fourwheel drive systems use a diff in the transfercase between the front and rear driveline. The downfall of this system is that if ANY tire losses traction, all the torque will go to that tire, leaving the other three just sitting there. The Q trac uses a LS diff to help elimenate this problem, however there is still some torque loss. The switch you refer to locks that diff(and the two drivelines).
jeepdaddy2000 is offline
post #9 of 9 Old 12-29-2003, 08:07 AM
Ruskie
Ruskie's Avatar
Thanks Jeepdaddy,
I understand the deal now. Kinda weird that they even built these rigs this way.
Ruskie is offline
QuadraTrac Emergency Drive Shift Valve and QuadraTrac Lever Info? LiftforPleasure Jeep CJ Forum 20 02-21-2014 03:33 PM
quadratrac kw89425 Jeep CJ Forum 1 07-06-2008 04:19 PM
How do I know if I have Quadratrac in a 79 Cj7? tvtoez Jeep CJ Forum 1 02-18-2008 09:41 PM
CJ with quadratrac durdenclub Jeep CJ Forum 22 08-17-2004 12:17 PM
Quadratrac shocka59 Jeep CJ Forum 2 11-06-2003 06:37 AM
