Quadratrac - JeepForum.com
post #1 of 3 Old 11-06-2003, 05:49 AM Thread Starter
shocka59
Quadratrac
I have a 76 CJ7 with quadratrac and a turbo 400 tranny and I was wondering if the quadratrac bolt pattern was the same as a dana 20 or 300 t-case so I could do a direct bolt on to the turbo 400. Keep in mind that the tranny came with the jeep so it has a AMC bolt pattern bellhousing.
Of all the things I have lost, I miss my mind the most.
shocka59 is offline
post #2 of 3 Old 11-06-2003, 06:14 AM
fuzz401
1978 CJ7
the only thing that fits on it is a q drive you will need a adapter and new out put shaft for a 20 or 300
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 3 Old 11-06-2003, 06:37 AM
wm69
.... you will also need a new rear axle assembaly as the qtrack rear pumpkin is offset to one side instead of centered like the d20/ d300
wm69 is offline
QuadraTrac Emergency Drive Shift Valve and QuadraTrac Lever Info? LiftforPleasure Jeep CJ Forum 20 02-21-2014 03:33 PM
quadratrac kw89425 Jeep CJ Forum 1 07-06-2008 04:19 PM
How do I know if I have Quadratrac in a 79 Cj7? tvtoez Jeep CJ Forum 1 02-18-2008 09:41 PM
CJ with quadratrac durdenclub Jeep CJ Forum 22 08-17-2004 12:17 PM
Quadratrac CJ7 Ditze Jeep CJ Forum 8 12-29-2003 08:07 AM
