quadratrac - JeepForum.com
post #1 of 5 Old 03-12-2002, 08:39 PM Thread Starter
Taylor
Post quadratrac
I have a 79 Cj7 with quadratrac, the only problem is the guy who owned it before me seems to have disengaged the 4 wheel drive mechanism. It seems that he just took out the shaft(sorry dont know terminalogy) that connects the front axle to back, but i dont know. I feel pretty stupid owning and driving a jeep with only 2 wheel drive. I am only a student, so dont have the money to really rebuild the jeep, I am just wondering what my options are, and if there is really anything wrong with it. If u think u can help but need to know more, write me back, and ask me the question, I will try to find u an answer thnx Taylor
Taylor Ricketts
Taylor is offline
post #2 of 5 Old 03-12-2002, 09:54 PM
Jacob
Junior Member
Post
if he took out the driveshaft you would just need to install another one. you should probably check the front diferential for oil before you engage the 4WD
but this is assuming the "shaft" you are talking about is the driveshaft that connects the transfer case to the front differential
Jacob is offline
post #3 of 5 Old 03-12-2002, 11:07 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
Rember to "unlock" the transfer case when you do. The control should be in the glove box.
bazinga
jeepdaddy2000 is offline
post #4 of 5 Old 03-13-2002, 08:20 AM Thread Starter
Taylor
Post
Thnx, for the replies, I will check the front differential this afternoon
Taylor Ricketts
Taylor is offline
post #5 of 5 Old 03-13-2002, 12:36 PM
Bulletproofcj7
Post
It soundslike he removed the front driveshaft to save on fuel mileage as i once did when i had Quadratrac. The font diff is still spinning however as they dont (normally) have lockout hubs.
I think i still have my old front driveshaft if you need one. It is in peices and cleaned and painted so it will need to be built, it is the cv joint type and is in sound condition the pin is not worn,and was out of an automatic, i dont know if that makes a difference or not, maybe someone on this board knows? $50. bucks if you want it.
jason
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
QuadraTrac Emergency Drive Shift Valve and QuadraTrac Lever Info? LiftforPleasure Jeep CJ Forum 20 02-21-2014 03:33 PM
quadratrac kw89425 Jeep CJ Forum 1 07-06-2008 04:19 PM
How do I know if I have Quadratrac in a 79 Cj7? tvtoez Jeep CJ Forum 1 02-18-2008 09:41 PM
Quadratrac CJ7 Ditze Jeep CJ Forum 8 12-29-2003 08:07 AM
Quadratrac shocka59 Jeep CJ Forum 2 11-06-2003 06:37 AM
