Quadra Trac Transfer Case Fluid - JeepForum.com
post #1 of 9 Old 12-01-2006, 07:13 AM Thread Starter
sefh
While doing some research on this fluid it sounds like they make a "special" fluid for these. Can some one tell me what fluid I can use and why is it so "special" and if there is something like it that I can use that is cheaper than $8.00 a qt.
sefh is offline
post #2 of 9 Old 12-01-2006, 07:26 AM
84 400
quadra tech wbe site sells it
84 400 is offline
post #3 of 9 Old 12-01-2006, 10:28 AM
elsplato
You can use 30w ND motor oil in place of it. For those who doubt look in the front of a Haynes repair manual. You can buy it for about 1/3 the price at any parts store.
elsplato is offline
post #4 of 9 Old 12-01-2006, 10:32 AM Thread Starter
sefh
Wow I have that 30w ND in the garage so I can use that?? Though I would have to buy that expensive stuff.... Thanks a million
sefh is offline
post #5 of 9 Old 12-01-2006, 11:06 AM
elsplato
No problem I have used it for years.
elsplato is offline
post #6 of 9 Old 12-01-2006, 11:14 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You will want to at least put some LS additive in there. While I have no knowledge of the vialibility of 30W, if the LS is in good shape it will chatter without the additive.
jeepdaddy2000 is offline
post #7 of 9 Old 12-01-2006, 11:38 AM Thread Starter
sefh
What is an "LS additive"?
sefh is offline
post #8 of 9 Old 12-01-2006, 12:28 PM
jeepdaddy2000
1971 CJ5
The Q track uses a cone style limited slip to aid biasing power to both drivelines. They are prone to chattering and erratic operation without the "special oil" or a limited slip additive.
post #9 of 9 Old 12-01-2006, 10:02 PM
John N
1981 CJ8
OK, so it's $8 a quart and takes 2.5 quarts (that's if you have low range too). $24 is cheap to not have to replace your transfer case. You'll only have to do this every few years....and that's if you drive it a lot.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
quadra-trac fluid for a 1976 CJ7 esteve999 Jeep CJ Forum 6 05-17-2012 08:46 AM
transfer case fluid drunkenrich Jeep CJ Forum 4 05-03-2008 03:03 PM
transfer-case fluid M79 Jeep CJ Forum 12 08-22-2007 04:27 PM
Quadra Trac Fluid sefh Jeep CJ Forum 4 10-31-2006 06:24 AM
Quadtra-Trac Transfer Case Brock Jeep CJ Forum 8 05-13-2002 08:07 AM
