Putting in thicker front driveline - JeepForum.com
post #1 of 7 Old 04-19-2013, 01:36 PM Thread Starter
CJ781
1981 CJ7
I had to rebuild my front driveline. I asked a machine shop if he could make a bigger one for me. He said in his experience that for a larger diameter shaft on a suspension lift of 4in on the CJ7 that the larger shaft is going to hit the cross member at full flex. He said I could put in a dual yoke to fix the problem but they tend to wear out faster. Any thoughts suggestions?
1981 CJ7 with a 4in Rough Country lift
CJ781 is offline
post #2 of 7 Old 04-19-2013, 02:08 PM
Renegade82
1982 CJ7
It will be close as it is with a 4" lift so he's got a point. Don't beef up the u-joints though, you want them to be the weak link in any drivetrain. They are the easiest and cheapest to fix, should things be over stressed. And the 30 isn't a brute to begin with.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #3 of 7 Old 04-19-2013, 02:12 PM
CSP
How big of a diameter are you wanting to go to?
CSP is offline
post #4 of 7 Old 04-19-2013, 02:25 PM
jeepwhore
I had a stock rear shaft retubed for my front. Had to notch the skid plate a little but it fit.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #5 of 7 Old 04-19-2013, 02:27 PM
agear
Yep, a lot of people just cut a notch in the skid plate
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
post #6 of 7 Old 04-19-2013, 03:02 PM
BeatCJ
1981 CJ5
I also have a re-tubed rear driveline in the front. I have a relatively short transmission (T-177), and have 1/2" clearance at full droop, 2 1/2" lift, though. All sorts of factors make a difference, motor mounts, transmission mount are all new on mine.
There are some things you will learn while holding a cat by the tail that can be learned no other way...
BeatCJ is offline
post #7 of 7 Old 04-20-2013, 12:19 AM Thread Starter
CJ781
1981 CJ7
Good to know. Not planning on much larger. Have to research it a touch more. Thx for the 411
CJ781 is offline
