Putting a "sleeve" in a frame... - JeepForum.com
post #1 of 5 Old 03-12-2009, 10:50 AM Thread Starter
86cj7pete622
The nuts that are inside the frame that take the shackle-mount bolts are either rusted, shot, or spin. I've heard solutions where you can cut access holes in the frame to repair the inside nuts and then patch up the frame again. I was thinking of something better....
My thought was to drill a hole on top and bottom of the frame and weld a sleeve (a tube) right through the frame so this way I can now run a bolt from top to bottom and never worry about bad hidden nuts again. Anyone try this before? Does it make sense to do? Thoughts? Suggestions?
My CJ is frame-off right now so my only reservation with this technique is if the bolt head that would now be sitting on top of the frame may get in the way of something (again, I can't tell right now because my Jeep is in a million pieces), but besides the possible bolt head having room issues, I think this method would be the strongest and best way of doing it. Would love to hear your thoughts.
Thanks,
Pete.
86CJ7, 258, 4" BDS, 33", completely apart....
86cj7pete622 is offline
post #2 of 5 Old 03-12-2009, 06:46 PM
gojeepin
1983 CJ7
I don't think I'd want a long bolt inside the frame. It could be rusting and you'd never know.
I'd cut a box around the old nuts, weld new nuts on a length of 3/8" steel plate, and weld that in the frame.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #3 of 5 Old 03-12-2009, 07:40 PM
BioTex
1979 CJ7
My factory frame has that done where the motor mounts bolt through the frame. Definately strong. I'd do it.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #4 of 5 Old 03-12-2009, 07:53 PM
imtheant
I had the exact same problem on my rear shackle mounts. My solution was a 1" hole saw. I drilled a hole in the side of the frame so I could easily access the old busted riv nut inside. I took a chisel and a hammer and knocked the riv nut out so I had a nice clean hole then used a new Grade 8 bolt nut and bolt to hold on the shackle. Nice thing about a 1" hole is you can stick a wrench in there and hold the nut from spinning so its not something you will need to worry about rusting or breaking off down the road. Another option is to just drill out the hole and tap it with a larger bolt.
1983 CJ7 - Project "Surf Jeep Restoration"
imtheant is offline
post #5 of 5 Old 03-12-2009, 08:50 PM
RockScar
Very common solution, and proven.
Live free or die. Death is not the worst of evils.
RockScar is offline
drilling "drain holes" in the bottom of my cj frame jedsled Jeep CJ Forum 10 09-25-2009 05:15 PM
Frame repair questions. "rookie edition" Patter Jeep CJ Forum 4 04-03-2009 04:45 AM
Any Advice on "Rustproofing" Windshield Frame Before Install? connor014 Jeep CJ Forum 14 01-14-2009 09:26 AM
"Tuff Stuff" inside frame? danholovic Jeep CJ Forum 9 10-26-2008 09:49 AM
My frame is finally back on its "feet"! gmshades Jeep CJ Forum 6 08-04-2007 08:56 AM
