Putting in a new defroster hose. 84 CJ-7 - JeepForum.com
post #1 of 11 Old 12-02-2009, 09:42 PM Thread Starter
quade
Am I missing something. This has got me frustrated to no end. I cannot get the new hose to fit and stay. The aftermarket hose's plastic clamps will not close and stay on. Has anyone else faced this problem and what did you do about it?
Thanks
quade is offline
post #2 of 11 Old 12-02-2009, 09:48 PM
CoryT
I am about to replace this on my 84 as well, as soon as it gets here, should be any day now. If the hose clamps they provide don't work, I have some big ol' tie straps that i will use. That and some duct tape and you should be good to go
CoryT is offline
post #3 of 11 Old 12-02-2009, 09:50 PM
scooter
1982 CJ7
I bought one from quadratec,same issue you have. Either end looked the same size,finally got it on the top section and clamped,the bottom clamp ripped off the hose and at that point I gave up on it. Its shoved far enough on the ducts it hasent come undown yet but it still pisses me off. If every part I had to replace on my Jeep was like this Id douse the bastage and gas and light it up.
scooter is offline
post #4 of 11 Old 12-02-2009, 09:55 PM
chet44
I bought one from 4wd.com and had the same issue. I used a heat gun set on low and lightly heated one end at a time. I put the top end on with the duct out of the jeep. Then I put the other end on the heater box, then mounted the duct. It was a PITA, and I did split the tube on one end, but it split where it is on the duct, so no air leak. It was tough, and frustrating, but doable. Plus, the duct and heater box had 2 small tabs that you slide the tube over before clamping so it won't come off. And I hate duct tape for permanent repairs. Sooner or later you have to go back and reapply the tape or fix it right and I hate doing things twice.
chet44 is online now
post #5 of 11 Old 12-02-2009, 10:01 PM
VaCJ79
1979 CJ7
I remember it being a PITA but it ended up going on. Its been over a year and still there with no problems. I'm not sure if this will help but when I put mine on I had the heater blasting to keep warm ( I did this in the middle of winter). The heat probably helped stretch the plastic.
1979 CJ7 258 / 4.0 head / J20 power Steering / T150 Dana 20 / EMU YJ 2" lift / Custom front bumper
Looking for : Please PM, Carter 2 barrel Carb before you through it out
VaCJ79 is offline
post #6 of 11 Old 12-02-2009, 10:18 PM
gmakra
Same problem here but I used aluminum foil duct tape. Having been in the HVAC industry for years this stuff works great as a permanent duct closure tape. This can be found in any store like Home Depot or Lowes in the duct isle.
gmakra is offline
post #7 of 11 Old 12-03-2009, 06:17 AM
Mike1084
1979 CJ7
Same problem here. Seems the hose is a tad to small to slip over the duct and get it to clamp shut. I ended up braking the clamp on one end it was so tight. I finally gave up and just used some zip ties.
Mike1084 is offline
post #8 of 11 Old 12-03-2009, 09:31 AM Thread Starter
quade
I believe that the zip tie thing is the way I'm going. I'll post later to let y'all know how it worked.
Thanks
quade is offline
post #9 of 11 Old 12-03-2009, 03:19 PM
Bubba Ray
I had to use duct tape.
Bubba Ray is offline
post #10 of 11 Old 12-03-2009, 08:31 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
If we're talking about the flexible duct from the HVAC box to the plactic defroster nozzle in the cowl, don't they still sell those at the dealer? I have a couple NOS Mopar pieces in the garage that I got a couple year ago.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #11 of 11 Old 12-03-2009, 08:37 PM
kickingprop
Zip Ties definitely FTW
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
Defroster Hose for 1976 CJ-5 Death_Eagle_571 Jeep CJ Forum 2 12-24-2009 08:22 PM
1977 CJ7 Fuel Filler Hose and Vent Hose elybarnard Jeep CJ Forum 8 07-26-2009 08:29 AM
Cj defroster sucks!!!!!! Please help. fitefire12 Jeep CJ Forum 5 03-27-2009 05:47 AM
Fuel/emissions hose as PS hose? supraman1990 Jeep CJ Forum 4 05-20-2008 11:36 AM
Defroster/ dehumidifier dieselchas Jeep CJ Forum 2 10-17-2007 05:07 AM
