Quantcast Putting a MC2100 on a 258 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Putting a MC2100 on a 258
Old 02-27-2008, 02:36 PM   #1
newjeeper17
I have the carb on and everything when we turn it on gas is coming out of the top of hte carb through (I don't even know what they are called) but two holes above the bowl and there is even a gasket that covers the holes. Anybody know what to do?
newjeeper17 is offline   Reply With Quote
Old 02-27-2008, 04:16 PM   #2
jeepdaddy2000
1971 CJ5
Stuck float. If it is a reman, take it back. If it is used, you can try giving the top of the carb a couple good raps. If that doesn't work, remove the carb and pop the top. Inspect the needle and seat for debris or damage. Check the float to see if it is bad(sunk), then readjust the float height. If you do a search, you will find lots of info on the subject.
jeepdaddy2000 is offline   Reply With Quote
Glock Forum
