putting a family bar in my 86CJ - JeepForum.com
post #1 of 32 Old 04-21-2011, 07:04 PM Thread Starter
Stroudcreek
well I am almost finished and let me tell you it was one hell of a job. I had to drill out every bolt and look what I found under the old CJ roll bar.
Stroudcreek is offline
post #2 of 32 Old 04-21-2011, 07:08 PM Thread Starter
Stroudcreek
Well you saw the before and here is the almost finished after, with the help of a good friend on mine and some 3M body adhesive. This is the same stuff they use to attach the roof on most all new vehicles. it will not come loose without applying a lot of heat and there was NO welding.
post #3 of 32 Old 04-21-2011, 07:11 PM Thread Starter
Stroudcreek
I thought my 86 looked kind of cool without a roll bar
post #4 of 32 Old 04-21-2011, 07:13 PM Thread Starter
Stroudcreek
Man this was way more of a job than I thought it was going to be
post #5 of 32 Old 04-21-2011, 07:14 PM
Turtle71
1983 CJ7
Originally Posted by Stroudcreek View Post
Well you saw the before and here is the almost finished after, with the help of a good friend on mine and some 3M body adhesive. The is the same stuff they use to attach the roof on most all new vehicles. it will not come loose without applying a lot of heat and there was NO welding.
Any more details or pictures? What panel material did you use?
Turtle71 is offline
post #6 of 32 Old 04-21-2011, 07:18 PM Thread Starter
Stroudcreek
Where are the the rivet nuts
post #7 of 32 Old 04-21-2011, 07:25 PM
MoC
Looking good. More pictures please!
MoC is offline
post #8 of 32 Old 04-21-2011, 07:39 PM
dd4bama
How do you intall the rivet nuts? Is that gun-looking thing a special tool?
dd4bama is offline
post #9 of 32 Old 04-21-2011, 07:43 PM Thread Starter
Stroudcreek
turtle71 there was a lot of prep work, my buddy that helped me with this is the owner of a very well respected body shop and he showed me a truck he was working on that had to have a new roof panel, the only thing that attached it the the rest of the body was this same glue. As far as the prep work goes, I took a small sand blaster and just keep going over the rust until it was all gone. I then primed the bare metal a can of self etching primer and painted it with a rattle can. Where the 3M adhesive was applied we used a grinder with a sanding disc on it to get the area rough. We then used self tapping screws to hold the patch panel down until it was cured, (24 hours) I also did the same thing on the bottom side so that there is no way for any water to get under the panel. It was not that hard to do, it just took some time.
The top panel is 16 gauge sheet metal. On the bottom I used lighter gauge because there was a lot more bending and shaping to get a good fit.
After 24 hours I removed all the screws and filled the holes with with the same 3M glue.
post #10 of 32 Old 04-21-2011, 07:49 PM Thread Starter
Stroudcreek
dd4bama yes that is a tool used to install the rivet nuts, it works kind of like a pop rivet gun, you just screw the rivet nut on to the tool, push it in and start pulling the handle until the nut is tight and unscrew it. You will need a 5/16 nut and bolt.
post #11 of 32 Old 04-21-2011, 07:51 PM Thread Starter
Stroudcreek
I will post more pic soon.
post #12 of 32 Old 04-21-2011, 07:54 PM
Turtle71
1983 CJ7
Seems like a good alternative if you don't have a welder. Are you going to use any seam sealer on the bottom...bedliner on the top?
Turtle71 is offline
post #13 of 32 Old 04-21-2011, 08:09 PM Thread Starter
Stroudcreek
Yes I will be using a lot of seam sealer I will make sure there is no way for any water to get under the patch. On the top side I have sprayed bed liner over the finished patch job before bolting in the new roll bar in
post #14 of 32 Old 04-21-2011, 08:25 PM
Turtle71
1983 CJ7
Cool! Looking forward to more pics!
Turtle71 is offline
post #15 of 32 Old 04-21-2011, 08:31 PM
supersport126
Jeep bolted in those roll bars and then painted the body. They are always rusted
supersport126 is offline
CJ 7 with YJ family bar 31matthew Jeep CJ Forum 9 04-23-2011 12:12 AM
New to CJ Family jeepjeepwhat Jeep CJ Forum 5 01-11-2010 12:22 AM
86cj soft top parts ? charliechicken Jeep CJ Forum 6 05-20-2009 05:23 AM
What carburetor in 86CJ 4Cyl AMC 150? Adjust? joemac421 Jeep CJ Forum 19 04-26-2008 08:30 PM
TF999 trans from 86CJ..in my 87 YJ COJAM Jeep CJ Forum 2 11-18-2005 02:41 PM
