Putt - putt from exhaust - JeepForum.com
post #1 of 5 Old 06-13-2011, 10:36 AM Thread Starter
84CJ7white
Last January on a cold night, CJ suddenly began sputtering going uphill. Had only been running 5 minutes. Here's what I have done in sequence since then in an effort to remedy condition.. Removed cat converter and replaced with straight pipe; complete tune up - plugs, wires, cap, rotor, fuel filter, cleaned carb; disconnected high altitude wire from block; repaced stock Carter carb with Webber; vacuum line to EGR valve was never present, so I removed EGR & plugged hole in manifold; oxygen sensor valve was never present; removed valve cover to check rods/springs.. all OK; replaced distributor with new one.... rotated for ideal timing.... Jeep still makes putt - putt noise.. exhaust is clear. Seems to worsen the longer I drive - sometimes to the point of stall. Anybody????
84CJ7white is offline
post #2 of 5 Old 06-13-2011, 01:54 PM
baldfatdad
1984 CJ8
Check the exhaust manifold bolts. They loosen. If not them check exhaust manifold for cracks.
baldfatdad is offline
post #3 of 5 Old 06-13-2011, 04:39 PM
Bubba Ray
I had a pushrod slip out from the rocker but you have checked that.
Bubba Ray is offline
post #4 of 5 Old 06-13-2011, 05:20 PM
keith460
Jeep. There's Only One
keith460's Avatar
Well, look at it this way, a Putt-Putt noise is better then a Chitty Chitty Bang Bang noise.
I guess I'm no help....
1984 CJ-7 Renegade
keith460 is offline
post #5 of 5 Old 06-13-2011, 05:29 PM
sanddrag
I'm wondering if it could be the ignition module.
sanddrag is offline
Fix Exhaust Leak or Buy Whole New Exhaust? MSBXCJ Jeep CJ Forum 5 04-08-2010 07:42 PM
Exhaust - Seal between Heat Valve and exhaust pipe Woolys_CJ7 Jeep CJ Forum 1 01-22-2010 07:07 AM
CJ 7 exhaust RangerOne Jeep CJ Forum 6 10-28-2009 07:37 PM
Which exhaust for 258 HighFive Jeep CJ Forum 11 10-04-2009 09:29 PM
Need help with exhaust for 80 CJ7 DaveatCJ7 Jeep CJ Forum 1 08-23-2009 03:03 PM
