Push Rods - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Push Rods
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 11-07-2014, 04:45 PM   #1
cj7red
Push Rods
Kind of a mechanical noob here trying to learn. Can somebody tell me why push rods spin while the engine is running? What purpose does that serve? I googled it and didn't find much.
cj7red is offline   Reply With Quote Quick reply to this message
Unread 11-07-2014, 05:56 PM   #2
RenoF250
To keep it concentric, if it stayed in the same place it would eventually wear oblong. Probably not critical in a pushrod but it matters for the lifters.
RenoF250 is offline   Reply With Quote Quick reply to this message
Unread 11-08-2014, 08:48 AM   #3
gmakra
If you look down the lifter gallery at the camshaft you maybe able to see that the lifters ride on about 50% of the cam lobe. The camshaft is cast iron and the lifters are hardened steel. Cast iron is pretty soft as metals go but it also has some outstanding properties for the application.
Please try to picture in your mind the lifter rides on about 50% of the camshaft, now as the camshaft rotates imagine the lifter spinning on the camshaft because the lifter is rolling on the edge of the camshaft. (almost like a ring and pinon gear)
This is done so that the lifter does not wear away (machining)the camshaft lobe.
The lifter will machine the cam lobe to the bottom profile of the lifter which has a slight rocker to it. Each lifter will wear to its corresponding lobe and when you change the location of the lifters on the camshaft or put new lifters on a old camshaft it starts the machining process again. The pushrod just happens to transfer this motion to the rocker arms.
gmakra is offline   Reply With Quote Quick reply to this message
Unread 11-08-2014, 04:33 PM   #4
cj7red
Originally Posted by gmakra
If you look down the lifter gallery at the camshaft you maybe able to see that the lifters ride on about 50% of the cam lobe. The camshaft is cast iron and the lifters are hardened steel. Cast iron is pretty soft as metals go but it also has some outstanding properties for the application. Please try to picture in your mind the lifter rides on about 50% of the camshaft, now as the camshaft rotates imagine the lifter spinning on the camshaft because the lifter is rolling on the edge of the camshaft. (almost like a ring and pinon gear) This is done so that the lifter does not wear away (machining)the camshaft lobe. The lifter will machine the cam lobe to the bottom profile of the lifter which has a slight rocker to it. Each lifter will wear to its corresponding lobe and when you change the location of the lifters on the camshaft or put new lifters on a old camshaft it starts the machining process again. The pushrod just happens to transfer this motion to the rocker arms.
So if one push rod is spinning slower than the others, there's probably something wrong with the lifter or camshaft?
Unread 11-08-2014, 07:42 PM   #5
gmakra
No, just as long as it spins
Unread 11-09-2014, 11:04 AM   #6
cj7red
Even if it's severely slower/barely spinning?
Unread 11-09-2014, 12:11 PM   #7
swatson454
swatson454's Avatar
1983 CJ7
I'd be calling that lifter and lobe done. Time to plan on a cam and lifter swap, IMO.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 03:20 PM   #8
RenoF250
Just the pushrod or the lifter as well? I would think it would be possible for the pushrod to be slowed by the rocker and not turn as fast.
Unread 11-09-2014, 04:20 PM   #9
cj7red
This isn't happening with my engine (that I know of). I saw a video where a guy was trying to diagnose what was causing one of his push rods to rotate much slower than the rest, and at that point I didn't even know they were supposed to spin.
I am planning on doing a 4.0 head swap and a performance cam at some point in the future, so I'm trying to learn what I can in my free time. Thanks for the all the info.
Unread 11-09-2014, 04:38 PM   #10
hutch1200
hutch1200's Avatar
1979 CJ7
Maybe the others are spinning too fast because the rocker is out of adjustment? Was it a roller rocker you saw in the vid? They are SOMETIMES, more prone to needing adjustment.
dual plane i didnt have any problems with 150 hp shot.........one thing thru the years running nitrous the engines respond a lot better to low rpm shift points....on the engines running 7000 rpm N/A...... with nitrous ran faster and more mph at a lower 5500- 6000 rpm shift point......
hutch1200 is offline   Reply With Quote Quick reply to this message
Unread 11-09-2014, 06:14 PM   #11
cj7red
No it was a flat lifter
