Push Rod/Lifter Replacement Question - JeepForum.com
post #1 of 4 Old 10-19-2009, 09:39 AM Thread Starter
Jonesie
1981 CJ5
I am in the process of rebuilding an AMC 360 from an 88 Wagoneer, and during disassembly, I found a bent push rod and that lifter was messed up on the same valve.
I'm going to have a local shop do the block and heads, which includes polishing the cam shaft. I seem to recall reading that if you replace the lifters, that you need to replace the cam. And if you replace the cam, you need to replace the lifters. Furthermore, when I disassembled the engine, I kept the rods and lifters in order, so they could be replaced in the same valve.
Can I replace just the one lifter, or do I need to replace all 16? Similarly, can I replace the one push rod, or do I need to replace all 16?
Also, if I can replace just the messed up parts, do I need a new cam shaft?
Thanks - David
Jonesie
1981 Jeep CJ5
Working on a 360 V8, T-176, D300 Swap
Jonesie is offline
post #2 of 4 Old 10-19-2009, 10:14 AM
jfwireless
1976 CJ7
If you have a faulty lifter and are rebuilding the engine I would just replace then all while you have it apart. As for the push rod you only need to replace the bent one.
Jim
jfwireless is offline
post #3 of 4 Old 10-19-2009, 11:50 AM
JeepHammer
Running On Empty...
1973 CJ5
Ditto.
New cam is better than trying to 'Polish' an old cam, and the same price.
New cam should ALWAYS get new lifters.
You CAN put a new lifter on an old camshaft if you have a lifter that goes out,
But NEVER reuse lifters on a cam if you can keep from it.
Lifters get wear patterns on both the cam face, and the lifter bore sides, and once 'Broke In' should never be moved around or reused with different camshaft.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #4 of 4 Old 10-19-2009, 12:54 PM Thread Starter
Jonesie
1981 CJ5
Thanks for the info. I'll be sure to ask my engine guy about this. As for the push rods, I should be OK replacing just the bent rod, right?
Thanks - David
Jonesie
1981 Jeep CJ5
Jonesie is offline
258 rocker bridges/Lifter replacement starfire340 Jeep CJ Forum 0 01-24-2010 01:45 PM
push rod and rocker jeepcj304 Jeep CJ Forum 9 03-04-2008 06:01 AM
Broken rod lifter-- Need a replacement happydog Jeep CJ Forum 7 02-21-2008 10:16 AM
Lifter question? BIGM Jeep CJ Forum 2 12-26-2006 06:12 PM
304 Hyd lifter replacement tet-ness-shot Jeep CJ Forum 4 08-23-2006 11:37 AM
