push rod issue with 4.2l - JeepForum.com
post #1 of 5 Old 01-10-2010, 04:14 PM Thread Starter
JimNut
86 Jeep CJ-7 with a 4.2l
Jeep was running great yesterday like it has been for a few months now. Went out today to pull it into the garage to work on some lighting and as soon as it starts it is backfiring/popping through the carb.
First thing I did was a compression check which turned out good. (All cylinders within 5% or so and around 110 psi) Checked a few other things and then decided to pull off the valve cover to make sure I didn't have a broken valve spring or something and found this:
Looked a little further into it and the push rod is not bent,valve spring seems okay, rocker is good. My question is what would cause this? Only thing I can think if is a collapsed lifter or something along those lines. As of right now the only way to get the push rod back under the lifter is to loosen the rocker and re-adjust.
Should I just put it back together and see what happens? I have a trip this upcoming weekend so I really want to get this figured out..
Thanks for the help!
Build it, Wheel it, Break it, Fix it and Repeat!
JimNut is offline
post #2 of 5 Old 01-10-2010, 04:19 PM
Fjguercio
1978 CJ7
if the push rod wears into the rocker and you see the wear pattern touch the hole in rocker... it will cover up the oil hole, no oil to rocker, it gets hot and not lubricated. That would be my guess.
Fjguercio is offline
post #3 of 5 Old 01-10-2010, 05:04 PM
CJunk
Pretty sure over reving can also make that happen. Do that lately?
CJunk is offline
post #4 of 5 Old 01-10-2010, 05:48 PM Thread Starter
JimNut
I'll definitely look into that! I just put the push rod back under the rocker and re-torqued everything and fired the motor up and everything seemed fine. Before I put the valve cover back on for good I will check that
Nope. Yesteday I just moved it around in the backyard and today I went to pull it into the garage to work on a few other things. Good thinking though
JimNut is offline
post #5 of 5 Old 01-10-2010, 10:04 PM
GeCJ7
This happen to me, however I thought the reason was that my motor had high miles. I too just reinstalled it, but it drop out very soon after. I took to a engine mechanic and they replaced the lifter and rocker arm with a new one. After that, all was well. Before all this, I used to have a bad lifter knock from a cold start for many years. I figured that the lifter was on its last leg.
GeCJ7 is offline
Electric fan .... push or pull CJ5Doc Jeep CJ Forum 4 06-13-2009 10:57 PM
Push Nuts (?) wvcj7 Jeep CJ Forum 4 04-07-2008 07:36 PM
push rod and rocker jeepcj304 Jeep CJ Forum 9 03-04-2008 06:01 AM
258 push rods DuggerCJ Jeep CJ Forum 0 09-11-2007 02:36 PM
Push Button Starter Scrambler82 Jeep CJ Forum 2 02-04-2004 04:18 PM
