Pulls to the right when I brake - JeepForum.com
post #1 of 10 Old 11-09-2011, 07:17 PM Thread Starter
David2012
My jeep pulls REALLY badly to the right when i hit the brakes. I have been mudding recently, could their be dirt stuck in the caliper or something? Its not the tire pressure. If im pulling right does that mean that its the left brake or that the rights brake is sticking? Its actually kind of dangerous because any hard braking makes me severely vere to the right, need a fix soon. Any help is much appreciated. David.
Electrical gremlins will be the death of me... 85 cj7
David2012 is offline
post #2 of 10 Old 11-09-2011, 07:46 PM
OrangeCJ-5
1978 CJ5
Kind of hard to say what is going on. If you have help, jack up the front and turn the front wheels to make sure no brakes are dragging. Then have someone push the pedal and see if both brakes are able the stop the wheels from being turned. If everything seems ok then I'd suggest pulling the calipers to physically check the pads for contamination
OrangeCJ-5 is offline
post #3 of 10 Old 11-09-2011, 07:50 PM
CJunk
You could have ruined a wheel bearing, but most likely it is a sticking brake caliper. Take it for a short run and look at the rotor. Which ever one smells bad, that's the one sticking.
Don't touch it, they stay hot for a while.
CJunk is offline
post #4 of 10 Old 11-09-2011, 07:57 PM
mopar346
Typically if it dives one way or the other it is the opposite side that has the problem. Make sure you didn't pinch a line shut during your wheeling, check the calipers and the slide. Again typically it is going to be in the front if it's that drastic. Wheel bearing is a thought or lose play in the front end, when you brake the tire will snatch to any area of free play.
Careful your character's showing
mopar346 is offline
post #5 of 10 Old 11-09-2011, 08:00 PM
gojeepin
1983 CJ7
Pulling to the right means the right brake is working more than the left for some reason... stuck caliper, contaminated pads, or line leak/kink.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #6 of 10 Old 11-10-2011, 03:39 AM
sbc61
I vote for the left brake caliper. Brakes are very important in most situations, so make sure they are in good working order. I would be a shame to dent your Jeep because you could not stop.
If you can't be handsome, you'd better be handy.
sbc61 is offline
post #7 of 10 Old 11-10-2011, 03:55 AM
wes97
Fix it asap. You might be able to salvage rotor/pads if you take care of it soon. Most likely sticking calaper. Either on the slides or the piston itself sticking. Either one is a pretty easy fix
wes97 is offline
post #8 of 10 Old 11-10-2011, 04:54 AM
wellmax
could be this:
rubber brake hose at wheel starting to deteriorate inside the hose.
normal issue with this problem:
when you release the brakes that wheel will continue to have braking as the brake fluid cannot flow backwards to the master cylinder, because the inside of hose has collapsed and holds the brake fluid under pressure, therefore, not releasing the brake.
but at this point anything is possible,
remember: "a vehicle that will not run will not hurt you, a vehicle that will not stop can kill you or someone else".
Giter her fixed~!!!!
wellmax is offline
post #9 of 10 Old 11-10-2011, 04:56 AM
wellmax
forgot to mention:
when you do get the brake issue fixed, please post what the problem was, others of us may need that information at a later date
thanks and have a safe day,
wellmax is offline
post #10 of 10 Old 11-10-2011, 06:02 AM
JeepHammer
Running On Empty...
1973 CJ5
I just LOVE those unschiduled lane changes when you step on the brakes,
And again when you let off the brakes!
It's pulling towards the brake that IS working.
If it tries to spin the steering wheel, it's a front brake.
If it just drifts towards the ditch or curb, it's probably a back brake.
Where I would start...
1. Check your master cylinder.
When you get low on brake fluid, one brake will stop getting fluid before the other, so you get a sideways dart.
2. Anytime you do brakes, you MUST start in the REAR!
Make sure your rear brakes are adjusted up, they have pad material on the Shoes, and there aren't any leaks.
3. Once the back brakes are checked/adjusted,
Move to the front.
Inspect ALL LINES FOR LEAKS! Front and Rear.
Then check the caliper on the LEFT SIDE.
Take it off the rotor, pump the brakes, see if the piston is working.
Be sure to leave the pads in place so you don't shoot the piston out of the caliper, which would be BAD.
Sometimes, the pistons get rusted into the bores, and they won't move.
Check pads, make sure they aren't shot.
Check rubber lines, look for leaks, cracks, ect.
A rubber line CAN degrade internally.
I've seen them NOT pass brake fluid they are so damaged internally...
If the rubber is cracked, or they are more than about 10 years old, CHANGE THEM.
When you are done with visual inspection, try bleeding the fronts, stating with left side, see if you get any air bubbling up out of the bleeder.
If you find air, then you have a leak.
Start looking for a line leak or leak at the piston seals.
The fact that you have ONE front brake working means your master cylinder is doing it's job, so it's probably NOT the master cylinder,
But I suggest you pull the carpet back, look INSIDE the vehicle, and between booster and master cylinder for fluid leaks.
Often times, when something goes, the rest of the system isn't in good shape either...
Mudding usually isn't a factor, other than to pack mud in everywhere you want to inspect now...
Mud is hard on pads, rotors, wheel seals, ect.
But it usually doesn't effect the brake calipers.
Since you use the brakes before the mud dries solid, it's usually pushed out of the way and doesn't effect the brake function.
Mud and Rust can effect the ability of the pads to move in the caliper,
And the caliper to move on the caliper mount, so while you are there, don't forget to use 'Never-Seize' on the moving parts of the brake brackets/caliper when you re-assemble. (Just keep it off the pad faces and rotor!)
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
brakes
Pulls hard right when I brake... Graffxman Jeep CJ Forum 3 03-09-2011 08:40 AM
Pulls to the right when I brake all of a sudden Dudman5703 Jeep CJ Forum 3 05-18-2010 07:58 PM
Jeep pulls hard left when i brake drunkenrich Jeep CJ Forum 9 02-10-2009 09:48 PM
70 cj5, pulls left on first brake famicom21 Jeep CJ Forum 3 05-24-2007 12:48 PM
Jeep pulls to right pf1130 Jeep CJ Forum 10 03-09-2007 05:07 AM
