Pulling a parade float question - JeepForum.com
post #1 of 12 Old 06-29-2013, 10:14 PM Thread Starter
davets
1956 CJ5
I told our cub scout pack I would pull a float in a parade with my '56 CJ5, f-head, 31" tires. About 3/4 mile route and just creeping along.
It's a tandem axle aluminum snowmobile trailer, 14' long "V" front with ramps. I'll have about 10 bales of hay on it. Assorted "props" which might weigh about 100 lbs. There could be as many as 25-30 cub scouts riding on it also with an average weight of say 80 lbs to be on the heavy side. I think I'll be alright in 2wd low-range. Do you agree?
*** 1956 CJ-5, milled head,elec fan,power steering,4-whl discs,rubber mounted cage,all drivetrain and engine incl distributor vented into firewall,Saturn overdrive,Lockrites,Rezeppa joints,2 1/2" springs arched add'l 1 1/2", homemade expanding shackles,reinforced frame,glass tub, stainless tank, 31X15.5 Terras on 15x10 and 15X12 rims-trail, 31X10.5 A/T's on 15X10 alum rims-street,Amsoil.
davets is offline
post #2 of 12 Old 06-30-2013, 04:13 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Yes.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 12 Old 06-30-2013, 05:45 AM
CJATE
That's what I do and it's almost perfect, 2low.
I REALY watch tongue weight. I do my best to have the people over the axels. Try to explain to one of the dads the issue. Have him police that.
Sent from AutoGuide.com Free App
83 CJ-8 scrambler
SOA
Locked and Twin-sticked
35's, fenders cut
4.56
bad paint
leaks just about everything
CJATE is offline
post #4 of 12 Old 06-30-2013, 07:01 AM
wellmax
I would go over your jeep hitch with a fine tooth comb. be sure it's tight and all it well. Brakes are in top condition.
also check with your insurance company and be sure you are covered.
local area, we had a family pulling a 16 ft. trailer with hay placed around so family members could set, Halloween family party.
grandpa was sitting beside 6 year old girl, someway she fell backwards out of the trailer and wheels of trailer ran over her,
I believe she died.
and they were just creeping through the back fields/woods on a family outing.
you want to help out, but in today's sue mentality, you have to protect yourself.
wellmax is offline
post #5 of 12 Old 06-30-2013, 07:09 AM
CJATE
Yep,
Sad day when you can't throw candy anymore, same reason.
83 CJ-8 scrambler
SOA
35's, fenders cut
4.56
bad paint
CJATE is offline
post #6 of 12 Old 06-30-2013, 07:15 AM
Double8racer
hey if your electric fan is on a temp switch you may want to consider putting a switch on it for now to keep it running all the time just for the parade watch hanging anything in front of the radiator signs and stay off the vehicle in front of you creep it along and she will be fine!!
Make sure that temp gauge works GOOD!!
and like previous post said check the insurance you think you know people till an accident happens then the evil comes out!!
good luck have fun and take some pics
Double8racer is offline
post #7 of 12 Old 06-30-2013, 08:42 AM
lucdog
lucdog's Avatar
1980 CJ5
Our Jeep club does a number of parades, most run 4 low with the front lockouts unlocked.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 12 Old 06-30-2013, 01:16 PM
only in a jeep cj
I've pulled a few heavy mardi grass floats and yes, 4 lo rear only ( hubs unlocked) and toggle between 1st and second gear. Starting out from the dead stop is the hardest. Higher rpm and feather the clutch a bit as the drivetrain could start jumping or hopping under the load. Don't want to jerk the float out from under their feet
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #9 of 12 Old 06-30-2013, 03:05 PM
82JeepCJ7
1982 CJ7
Since this will be on flat ground, I have seen people put a block of wood between the axle and the frame to keep the rear of the vehicle from sagging. Make sure they are secured so they wont fall out. Just make sure you take them out before you drive home....
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #10 of 12 Old 06-30-2013, 04:21 PM
tjeep1
1978 CJ7
parade
i was crushed in a 4th of july parade 2 years ago,have fun but be careful accidents happen when you think they wont
tjeep1 is offline
post #11 of 12 Old 06-30-2013, 05:48 PM Thread Starter
davets
1956 CJ5
[QUOTE=Double8racer;15623898]hey if your electric fan is on a temp switch you may want to consider putting a switch on it for now to keep it running all the time just for the parade watch hanging anything in front of the radiator signs and stay off the vehicle in front of you creep it along and she will be fine!!
I have my fan set so it comes ON at 180. I can also turn it OFF for water crossings then I can also run it ON full time. Even though...I did still pull the fan and put my stock fan back on. I think it pulls more air. I'm also going to use the elec fan under a stack of wood with orange paper mache stapled to it. I'll be able to use my fan switch to turn the "campfire" on and off.
Umbrella policy here I come. I didn't even think of that.
davets is offline
post #12 of 12 Old 07-01-2013, 03:41 PM Thread Starter
davets
1956 CJ5
Hooked onto my 4,550 lb minivan and I was surprised how easily she got her rolling. Pretty much just above idle to get her rolling then idle in low-low. She rolled at a pretty good pace at idle. Thanks.
Insurance co. will cover me but only because the policy doesn't exclude pulling parade floats. They wouldn't allow me to raise my coverage or get an umbrella policy until after the parade.
davets is offline
