Which puller for model 20 diff bearings - JeepForum.com
post #1 of 14 Old 02-15-2012, 06:49 PM Thread Starter
only in a jeep cj
I see there is two small areas cast into the case at opposing ends of the bearing area so the puller arms can hook the race edge for the pull.
My question is which puller is best and will fit this application. I don't want to buy a Craftsman with non locking arms and too wide of an arm when autozone or whoever has the correct one.
So who has the best puller?
THANKS
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #2 of 14 Old 02-15-2012, 09:52 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You have two choices. Either a bearing splitter
http://www.google.com/imgres?q=beari...d=0CKMCEK0DMDI,
or this specialty tool http://www.pirate4x4.com/tech/billav...w/IMG_3287.jpg
I own the second and it is unparallelled for removing pinion and carrier bearings. It is, however, much more expensive than a bearing splitter and a 2 jawed puller.
jeepdaddy2000 is offline
post #3 of 14 Old 02-15-2012, 11:09 PM
Outnumbered
Links dont work for non pirate 4x4 members. Can you tell us what they are? thanks
1985 CJ7, 258, TF999, D300, D30, AMC20, 4.5" lift, 33" BFG's
Outnumbered is offline
post #4 of 14 Old 02-15-2012, 11:29 PM Thread Starter
only in a jeep cj
Yeah, Ive seen this tool before. I just want to really confirm it will work on a Model 20 as there is no lip under the bearing other than those two indent areas. Some places say it will work, but for 350 bucks, I want to be sure. I will be using it on 44s and 60s as well, but need it now on a 20.
I see the splitter/puller combo too. Will that mess up or distort a good bearing during the pull?
Thanks
http://www.performance4trucks.com/Dr...13&t_pl=101717
Ed
1975 CJ-6 1983 CJ-8
post #5 of 14 Old 02-16-2012, 12:13 AM
80cj
80cj's Avatar
1980 CJ5
I use a Snap on differential bearing puller. This OTC set is almost an exact duplicate of what I use and cheaper. OTC makes good tools. http://www.usatoolwarehouse.com/usat.../otc-4520.html
80cj is online now
post #6 of 14 Old 02-16-2012, 05:06 AM
jeepdaddy2000
1971 CJ5
Thanks
The splitter is a multipurpose tool. That being said, yes, it can distort/pull the cage off the bearing. The G2 tool that only in a jeep was kind enough to post (sorry about the link, did a quick search for an image and that was the first to pop up) is a bit more limited in it's basic form, but is very safe. I have literally pulled hundreds of bearings from numerous applications with it and never lost a one. I purchased mine from Mac about 25 years ago . I think I payed about the same price back then!
It is "the" tool to have. The issue is, is it worth spending that kind of money for something you may only use a couple of times. You could probably get a local mechanic to finish the install for about the same price or even less.
post #7 of 14 Old 02-16-2012, 10:09 PM
80cj
80cj's Avatar
1980 CJ5
Many diff cases have puller notches that are too small to allow purchase on the bearings with a finger type puller so I grind the notches deeper with a Dremel tool. This is helpful especially on Dana axles since you're actually pulling against the shim pack and you stand a good chance of damaging shims especially if the puller fingers slip. For that same reason, when working on Dana axles, I arrange the shims so that the thickest shim goes on the diff bearing journal first, that way it is less likely to be damaged by the puller. Of course, when working on Dana axle you should have a sufficient assortment of shims to allow for ones that get damaged. If you can afford it, the G2 type tool is the way to go. I'm still trying to justify the price and shipping cost of one.
80cj is online now
post #8 of 14 Old 02-16-2012, 10:16 PM
lucdog
lucdog's Avatar
1980 CJ5
I've had the Harbor Freight bearing splitter for 2 years. Tried to use it one time.
It looks nice in the case, and that's about it.
I would not recommend even thinking of buying it.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #9 of 14 Old 02-16-2012, 10:26 PM Thread Starter
only in a jeep cj
Yep, I am wanted to NOT distort the bearings for several reasons....
Looks like the G2 tool is the way to go. My wallet isn't happy, but the Jeep will be.....
Thanks for all the input.
Ed
1975 CJ-6 1983 CJ-8
post #10 of 14 Old 02-16-2012, 10:58 PM
80cj
80cj's Avatar
1980 CJ5
Jeepdaddy,
Can you use a G2 type tool for pulling pinion bearings too?
80cj is online now
post #11 of 14 Old 02-16-2012, 11:21 PM Thread Starter
only in a jeep cj
Originally Posted by 80cj View Post
Jeepdaddy,
I just watched this so here it is
About 1:35 on shows the inner pinion bearing pull...
Ed
1975 CJ-6 1983 CJ-8
post #12 of 14 Old 02-17-2012, 12:37 AM
80cj
80cj's Avatar
1980 CJ5
Thanks! I guess that explains why the puller is as tall as it is.
80cj is online now
post #13 of 14 Old 02-17-2012, 05:01 AM
jeepdaddy2000
1971 CJ5
A couple of things...
First, many guys use a set of "set up" bearings. These have been hones to a slip fit on the carrier. Set up the backlash with the set up bearings, then press the new ones on when you get it right. This eliminates the multiple pulls to get the picture right. You may be able to go this route in stead of the puller. Know you may have to pull the bearings in the end anyway if something ends up going wrong.
If you get the puller, a couple of things to note.
Insure the bottom ring is flat on the race and completely on the puller body.Don't let threads show on the bottom or spin the ring below the body. Place one clamshell on, then spin the upper ring up tight against it. Install the second clam shell, then the retaining ring. This insures there is no slop, which will allow the race to ride up off the bearing.
I agree, it is a horrible price for a tool that probably cost ten dollars to make. It will, however, insure your not trying to chisel off a race stripped of its bearings and cage. It can also be used for any bearings you can get it to fit on. In the end, you may be able to e bay or craigslist it and recoup some cash.
post #14 of 14 Old 02-17-2012, 12:55 PM
80cj
80cj's Avatar
1980 CJ5
I mentioned Dana axles in my previous post and for those, setup bearings as Jeepdaddy mentions saves time in pulling and reinstalling carrier bearings. But in the interest of addressing the OP's inquiry regarding the AMC 20, the nice thing about the AMC 20 (like a Ford 8.8 and GM 10 and 12 bolt) is that the carrier bearing shims are located between the bearing cup (race) and the housing so you only need to install the new bearings and that's it. No reason to have to remove themfrom the carrier again.
80cj is online now
Model 20 diff and 1 piece axles mylittlecj5 Jeep CJ Forum 6 02-01-2012 01:06 PM
model 20 axle bearings st-4 Jeep CJ Forum 0 06-06-2010 01:49 PM
Diff bearings Indy Jeep CJ Forum 4 04-21-2007 01:49 AM
1981 model 20 axle bearings bugeater Jeep CJ Forum 6 10-17-2003 04:13 AM
Model 20 diff. question hollywood Jeep CJ Forum 12 02-11-2003 04:16 PM
