Pulled my plugs and! - JeepForum.com
post #1 of 17 Old 01-14-2010, 03:46 PM Thread Starter
Donobrew
So I pulled my plugs last night to take a look at them. What I saw was 5 of the 6 plugs were caked with ash/gray deposit on one side of the plug. The #6 plug looked “normal”.
I did some research on this and found out that either I’m using cheap gas, cheap oil and or I have an oil leak in the cylinders from worn valve guides or valve seals. I have notice that I add quart of oil right around the 3000 mile mark so when I’m down a quart I know its time for an oil change…
If it is worn valve guide/valve seals how difficult is that to replace?
Donobrew is offline
post #2 of 17 Old 01-14-2010, 04:04 PM
PERK
how many miles on the engine? have you done a compression check?
PERK is offline
post #3 of 17 Old 01-14-2010, 04:13 PM Thread Starter
Donobrew
Between 20-40k on this engine. I had the cam replaced about 10,000 ago and I believe the seals were replaced at that time too... I need to fine the receipt... You would think the mechanic would replace the valve seals...
I haven't checked the compression yet... What should it read?
Donobrew is offline
post #4 of 17 Old 01-14-2010, 06:04 PM
halpeters
1978 CJ7
Put new plugs in - and don't get anything fancy - AC Delco plain plugs are perfect. Verify the plugs are the correct heat range and gap for your engine. Jeephammer has good suggestions on what to use.
Do a GOOD tuneup - again follow Jeephammers advice - use a GOOD cap and rotor with brass terminals and good wires. Check timing.
Run for 3000 miles and check the plugs again.
A quart of oil in 3000 miles is NOTHING.... A quart in 500 miles isn't really anything to worry about...
Remember, this is 1960's or older technology that we are running. Back then everything burned and leaked oil, and needed tune ups every 3000 to 12000 miles. Back then, the plugs you describe would have been cleaned, regapped, checked and reinstalled without a second thought...
This ain't "new HONDA drive it for 100,000 miles before doing anything" stuff....
1978 CJ-7
halpeters is offline
post #5 of 17 Old 01-14-2010, 09:20 PM
Thumperk15
1992 XJ Cherokee
Grey? If it's not oily or wet looking it's not bad. Am I the only one that has posted here that pulls plugs and put them to my nose and simple take a sniff?Does it smell of gas(possible not adjusted carb), or oil(hopefully valve seals)? I'd do that first and if it's grey, burnt gas and exhaust look and smell.
Thumperk15 is offline
post #6 of 17 Old 01-14-2010, 09:24 PM
Thumperk15
1992 XJ Cherokee
Would bad gas or cheap oil not cause the one plug to be normal looking and the other 5 be bad? Also, the majority of the time a engine goes it's the last # cylinder.
post #7 of 17 Old 01-15-2010, 06:48 AM
Mike Romain
You would be blowing a lot more than one quart of oil between changes if the seals were bad, I would suspect the gas additives and would be wondering why #6 wasn't firing right.
I sometimes test the spark plug wires by spray misting them with water in the dark. If any are leaky for spark it shows up nice. I would also be inspecting the inside of the distributor cap with a strong light at the #6 spark plug post looking for a spiderweb type mark.
Mike
Mike Romain is offline
post #8 of 17 Old 01-15-2010, 07:52 AM
Thumperk15
1992 XJ Cherokee
Water on the wire at night? If the nights were warm and I had time at night that sounds cool. I however simply take a screwdriver, stick inside, and lay it close to metal while holding the plastic handle, you should clearly see it jumping during the daylight.
post #9 of 17 Old 01-15-2010, 07:55 AM
Thumperk15
1992 XJ Cherokee
When I read #6 as being "normal" looking I see it as firing just fine, could be wrong though.
post #10 of 17 Old 01-15-2010, 10:24 AM Thread Starter
Donobrew
I had to hit the first 5 plugs with a wire wheel pretty good to clean them up. The #6 plug wasn’t nearly as bad as the others. I hit it with the wire wheel for a spilt second to clean it…
I’ll do an oil change and tune-up (new plugs, cap, rotor and wirers) and re-check the plugs in 3000 miles to see what they look like.
Mike, when you say “Fuel Additive” I’m not adding any to my fuel. Would it be from what the gas companies add to your fuel?
Troy
Donobrew is offline
post #11 of 17 Old 01-15-2010, 03:12 PM Thread Starter
Donobrew
Its time for a tune-up! I last time I changed the plugs, wirers, cap/rotor was in July 08 when I did the TeamRush upgrade. Its been 18 months about 14,000 miles…
Donobrew is offline
post #12 of 17 Old 01-15-2010, 03:40 PM
swatson454
1983 CJ7
I think Mike is referring to a procedure that can be used to test the wires themselves. When done like he mentioned, you can sometimes see the wires arcing all over the place. It's really neat if it's an automatic. You can have a buddy "power brake" it and watch the light show under the hood if the wires are bad.
Holley Carb Tuning
swatson454 is offline
post #13 of 17 Old 01-15-2010, 06:51 PM
scooter
1982 CJ7
14K miles isnt a lot for plugs or anything else either tune up wiseand 3k per quart burned is pretty darn good,my old K5 burned a quart ever 300-400 miles and the plugs never fouled,gotta be some bunk gas ,weak spark or something else.
scooter is offline
post #14 of 17 Old 01-16-2010, 06:06 AM
Mike Romain
Troy
Yes, you can't just buy 'gasoline' anymore.
Mike
post #15 of 17 Old 01-16-2010, 06:08 AM
Mike Romain
Yup, that shows you have spark and we figure the OP 'does' have spark. The mist of water is to find leaky wires. The light show can be wicked with bad wires.
Mike
Value of Pulled 258 Engine KUJeeper82 Jeep CJ Forum 8 07-02-2009 08:45 AM
AMC 401 Oil Gallery Plugs / Freeze Plugs Hybrid Jeep Jeep CJ Forum 1 04-22-2008 01:26 PM
I pulled the head wifflesniffle Jeep CJ Forum 2 03-02-2008 09:19 PM
just pulled the 304 brently1216 Jeep CJ Forum 1 11-15-2007 10:38 AM
We got the Tranny pulled jrylb73 Jeep CJ Forum 5 02-25-2007 12:27 PM
