Pull fuel and temp gauge from speedo cluster - JeepForum.com
post #1 of 6 Old 02-27-2002, 02:27 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Post Pull fuel and temp gauge from speedo cluster
I found a site that tells you just about everything you need to know about these gauges except how to take them out and put them back. I can't see what hold em in. Do ya think I have to pull out the whole speedo cluster to do it?
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #2 of 6 Old 02-27-2002, 11:30 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
If you are trying to replace your gauges in the speedo cluster, you need to take it out. the back of the cluster is held on by bending it around the front. carefully straighten the four crimps and the back will come off. The gauges are attached by a couple of nuts on the studs to the back. When you are done replacing the gauges, simply rebend the crimps and you are back in buisness.Good luck
bazinga
jeepdaddy2000 is offline
post #3 of 6 Old 03-02-2002, 07:06 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Thumbs up
Thanks JeepDaddy2000. I just finished replacing the gauges. I'm somewhat successful. The temp gauge works now, but the fuel gauge is still working whacky. I know it's the sending unit now. I bought a new sending unit a couple of weeks ago, but it was defective from the get go. I tried to solder the broken wire but wound up trashing the thing. It was a cheep piece of trash anyway. I'll purchase a better brand next time. I guess it's time to drop the tank. I just filled it up with gas so I'll wait until I run it out of gas. At the same time I'll replace the filler tube and vent tube.
You ever drop a gas tank? Anything I should watch out for other than the usuall fire hazards? I know a guy that burnt himself up in his garage pulling his tank next to the water heater. I'll turn off the pilot and gas before I start that job.
post #4 of 6 Old 03-03-2002, 11:05 AM
jeepdaddy2000
1971 CJ5
Post
Just remember that all your wires and fuel lines attach to the sending unit that is located on the TOP of the tank.It is usualy a simple operation, just remember if it doesn't want to come out, check to make sure everything is unhooked. I know this sounds stupid but safety is common sense. Do it in a ventelated space away from fire. you will get some gas and fumes around as be ready. PS this is a good time to wear safety glasses as there will be dirt falling in your face.
bazinga
post #5 of 6 Old 03-04-2002, 09:53 AM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Post
JD2000 - can the sending unit be removed without removing the tank? I vaguely remember reading something about an access plate under the back seat for fuel tank access. I don't have any idea how large it is, or if it exists. Also, Do you know of a quality sending unit. The last one I bought was trash before I got it out of the box.
post #6 of 6 Old 03-05-2002, 12:10 AM
jeepdaddy2000
1971 CJ5
Post
Well, you can cut an acess hole if you like(I've thought about it myself!)Four Wheel Parts Wholesalers used to carry a good unit, might try them
bazinga
Temp gauge and fuel gauge quit Foulplay Jeep CJ Forum 11 11-09-2012 09:43 AM
CJ7 Fuel & Temp gauge cluster problem CrazyHorse6 Jeep CJ Forum 23 07-08-2012 03:03 PM
TEMP GAUGE, FUEL GAUGE, AND SPEEDO HELP PlEASE cgi2099 Jeep CJ Forum 8 11-03-2009 05:49 PM
Temp Gauge not working (atypical caps on back of speedo) cb_cooke Jeep CJ Forum 6 02-21-2009 02:46 PM
Speedo, Fuel Gauge and Temp gauge not working KYCJ7 Jeep CJ Forum 1 07-07-2008 12:41 PM
