Prothane motor mount + shim plates - JeepForum.com
post #1 of 9 Old 02-15-2012, 10:06 PM Thread Starter
Orlie
I bought a set of Prothane motor mounts for my 86 CJ7 258. One side had the shim the other did not but this is not the concern, if I need to make one no problem. My question is do I need the shim plates for support or are they for alingment. The shim sits between the motor mount and the motor mount bracket which attaches to the engine. The old motor mount measures 1.7160(I know it is compressed) with the shim and the new motor mount measures 1.7235 with no shim with the shim its 1.9115. Now the new motor mount flange is .1750 which is almost the same thickness as the old motor mount flange and the shim together. So after all that do I need the shims. Hope this made sense.
Orlie
Orlie is offline
post #2 of 9 Old 02-16-2012, 09:35 AM
fredrok
Orlie, you approached it the same way I did. With those figures, I just left the shims out (I had 1 on each side) and really don't think I'll ever see an issue doing so.
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline
post #3 of 9 Old 02-16-2012, 10:26 AM
Outnumbered
I also ran into this problem. Prothane did not ship directions. I left out the factory shim plates also. The only problem it created is the exhaust is about 3/8 inch from the motor mount and that was after much adjusting of the pipe. So I wrapped the pipe in header wrap and hope it does not get too hot. The shims would give me another 1/4 to 3/8 I suppose.
One other thing, the gold anodized plates molded into the mounts need to point up. I did not know this and pointed them down. Later found a picture on prothane website with them pointing up. I wish they would have included some basic instructions
1985 CJ7, 258, TF999, D300, D30, AMC20, 4.5" lift, 33" BFG's
Outnumbered is offline
post #4 of 9 Old 02-16-2012, 10:41 AM Thread Starter
Orlie
Thanks for the info, I agree with leaving the shims off the motor mounts. I did some research on the frame tie in bar to keep the frame from opening up. My
CJ7 did not come with one and was wondering if anyone has a good picture of it or know where I can get one. The picture would be great just incase I need to make one
Orlie
Orlie is offline
post #5 of 9 Old 02-16-2012, 10:42 AM
Outnumbered
Orlie
I got one on ebay for $25 shipped. I'll post a pic later for you.
post #6 of 9 Old 02-16-2012, 11:19 AM
sherlocktk
I almost posted this exact same question yesterday too. I have The energy suspension mounts, which are very similar. The metal on the aftermarket mounts is the same thickness as the shim plate. The only "structural" reason I would thing it woudl be there is on "stock" mounts the metal is pretty flimsy where on the aftermarket kits the metal is strong. Maybe the shim plate was in effort to help beef up the connection to the stock mounts? I left mine off as they seemed the right size without it.
sherlocktk is offline
post #7 of 9 Old 02-16-2012, 11:43 AM Thread Starter
Orlie
Got a Link
Orlie
Orlie is offline
post #8 of 9 Old 02-16-2012, 04:20 PM
Outnumbered
Here ya go. I also included a pic of the exhaust pipe/mount clearance. I used a new Walker downpipe. My OEM pipe was crushed from the PO when the motor mount failed
You can see the motor mounts are installed opposite of how Prothane shows them on their website (thanks for including instructions Prothane) I plan to flip them when I do my RMS and oil pan gasket.
Excuse the mess of wires and jackstand storage area She is not quite in running condition yet
post #9 of 9 Old 02-16-2012, 07:14 PM
fredrok
Mine don't have that extra extension of metal but I can't imagine why it would even matter how they're positioned. The reason they probably don't offer instructions with the product is because it doesn't matter if it's up or down.
fredrok is offline
Motor mount shim plates? Turtle71 Jeep CJ Forum 3 02-04-2012 06:15 AM
4.2 Liter motor mount bracket to block specs and motor mount nut and 2 bolts specs agear Jeep CJ Forum 4 11-14-2011 03:29 PM
258 Motor mount Plates Strings72 Jeep CJ Forum 5 12-15-2009 09:55 PM
Prothane Motor Mount Question NWA_CJ7 Jeep CJ Forum 0 07-22-2009 07:06 PM
Need motor mount engine plates fabricated 258 mounts to 2002 4.0 whittlecj Jeep CJ Forum 23 11-29-2008 11:50 PM
