Prospective CJ5 owner. Need advice! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Prospective CJ5 owner. Need advice!
Save 17.76% for the 4th of july with ruffstuff specialtiesJuly 4th Sale Event! and Yes, We're Open!Metalcloak: Celebrate Freedom with Free Shipping
Unread 07-12-2013, 02:30 PM   #1
jgk1013
Hey, all.
So, I sold my JGC last year and have been dormant on here. Driving a soul crushing sedan and need some adventure back in my life.
I'm looking at buying this CJ5:
Link
I have to admit that I am NOT much of a handyman when it comes to cars. What are the pertinent questions I need to ask before buying? What kind of costs do you think I should expect?
Any general pointers? Good idea? Bad idea? Thanks for your input.
jgk1013 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 02:48 PM   #2
my73CJ
1973 CJ5
way too expensive with a shot tub 2-2.5K max IMO
my73CJ is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 02:52 PM   #3
Jeeper44mag
1978 CJ7
"Tub has rust, but so far gone it can't be saved".
Unless this is a typo and he meant the opposite, don't even THINK about it unless you're ready to pump another $3000+ into it after you buy it.
I bought a rusty hulk once, and would NEVER do it again.
Luis
Had: '75CJ5 (back when they still made them), '76CJ7, '99 TJ.
Have: Metallic Silver '78 CJ7 Golden Eagle, 304 V8, ps., pb., A/C, ~3" Lift, 12.5"x33"x15 BFG AT's., T150/Dana20, Dana30/AMC20, 4.56 gearing, white hardtop.
Jeeper44mag is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 03:15 PM   #4
Gigemags05
1980 CJ7
I'm pretty sure that's a typo and he means that the rust isn't too bad.
That's a pretty normal price around here ( texas).
Gigemags05 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 03:23 PM   #5
jgk1013
I asked about the rust, to which he replied "There is a little rust on tube, easy to fix."
Unread 07-12-2013, 03:56 PM   #6
Jeeper44mag
1978 CJ7
In that case, go for it!
Luis
Unread 07-15-2013, 11:17 AM   #7
jgk1013
I took a look. Tub pretty bad and rusted through in one spot.
Looking at this alternatively: Link
Unread 07-15-2013, 11:34 AM   #8
HeathFinnie
1976 CJ5
I like it. Especially the vice grips in the ignition
HeathFinnie is offline   Reply With Quote Quick reply to this message
Unread 07-15-2013, 12:29 PM   #9
jgk1013
Ha! Had not even noticed.
Unread 07-16-2013, 06:43 PM   #10
jgk1013
Ok, here's here's the deal. That CJ7 needs a new carb and ignition switch. Can someone ballpark cost and headache associated with these fixes?
Unread 07-16-2013, 06:49 PM   #11
Jbwardfamily
1978 CJ5
The carb cost can go anywhere from $200 to $1000. It is all based on your wants/needs. Ignition switches are fairly cheap but can lead to other problems. I wouldn't let either stop me from buying one.
Jbwardfamily is offline   Reply With Quote Quick reply to this message
Unread 07-16-2013, 06:57 PM   #12
Gigemags05
1980 CJ7
You can get a weber carb for $200-$250 and its not very difficult to install and get running right.
The switch is about $15 and is as simple as unplugging the old one a d plugging the new one in... As log as you can get your hands on it. It's right on top of the steering column behind the dash. I changed mine the other day in about 15 minutes.
Unread 07-16-2013, 08:22 PM   #13
John Strenk
John Strenk's Avatar
1976 CJ5
It's probably not the switch but the key tumbler but still around the same rice to fix.
CJ7 is much more roomier than a CJ 5
It already has a Weber on it.
Probably needs to find vacuum leak...
And rotate that Fuel filter the right way...
And update that distributor....
Horn button and both wipers would be nice also....
Did you hear it running yet?
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 07-16-2013, 08:29 PM   #14
Gigemags05
1980 CJ7
I saw the weber on it, which was why I stated the price of a new one. Of course he could probably just rebuild the current one for less.
Unread 07-16-2013, 08:35 PM   #15
John Strenk
1976 CJ5
Ahh.. I see
I hope he can see it running, or trying to run before he buys it though.
On a different note ,I'd like to point out that dirty Webers don't work either.. Just like dirty BBD's.
Sorry, had to point out dirty carbs are all the same...
