Proportioner Valve Wire - JeepForum.com
post #1 of 7 Old 06-28-2013, 02:35 PM Thread Starter
Chlarock
I ran all new brake lines and installer a new proportioner valve. I went to plug in the valve and find that the valve has one wire connection and the harness wire has two wires. Can this be retro fitted or do I have to replace the prop valve? Its a cj7 with a yj interior so I had to use the yj harness for the transition from engine compartment to interior.
Chlarock is offline
post #2 of 7 Old 06-28-2013, 02:42 PM
LumpyGrits
IIRC, 1 wire goes to the p'brake.
LG
LumpyGrits is offline
post #3 of 7 Old 06-28-2013, 05:17 PM
Ollie09
1983 CJ7
Connector
If the switch has a shroud around the center terminal, then this is the connector you need.
http://inlinetube.com/Prop%20Valves/PR201.htm
Ollie09 is online now
post #4 of 7 Old 06-28-2013, 05:54 PM Thread Starter
Chlarock
Yes, that is what I would need but what wire does it connect to on the two wire harness connection coming from the engine compartment wires?
Chlarock is offline
post #5 of 7 Old 06-28-2013, 08:32 PM
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
I think you just splice the two wires together with the single wire. I say "think" because that's what I did but haven't hooked it up to see if it works yet. I got that info from the experts on here.
Do a search "converting brake pressure switch from 2 wire to 1 wire configuration"
Guy Smilie is offline
post #6 of 7 Old 06-28-2013, 09:25 PM Thread Starter
Chlarock
I'll do that search. I also "Think" you may be right so maybe I'll just splice em and see if it works.
Chlarock is offline
post #7 of 7 Old 06-29-2013, 07:37 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes, That's all you need to do.
One wire runs to the parking brake and other wire runs to ignition switch.
The ignition switch connection turns on the brake warning light so you know the bulb is working before you drive. It just grounds the circuit momentarily when cranking.
John Strenk is offline
