Proper ground after nutter - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Proper ground after nutter
JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFAlloy usa heavy duty ball joint kitsROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 09-24-2014, 07:39 AM   #1
thirstybob
Junior Member
Request for a little guidance please. I performed the nutter bypass, removed the excess wiring and reloceated a new ICM to the passenger side fender well. I'm experiencing a few electrical issues and I'll say, that I had no issues prior to this. One is that after this modification I have no back up lights and the e-brake light stayed on or flickered. Two, I now have back up lights??(I don't know when they came back on??) but the passenger side brake light does not work. Three, the turn signals do not flash with the head lights on, they do flash with the head lights off.
I'm suspecting that it's a ground issue. Any suggestions would be greatly appreciated and thanks in advance.
thirstybob is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 07:46 AM   #2
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Did you remove the battery to tub ground when you removed all the computer related wiring?
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 07:54 AM   #3
thirstybob
Junior Member
Matt
Thanks for the quick response.
I don't recall. Where would I look? Is it as simple as the Neg cable pigtail grounded to the tub?
Unread 09-24-2014, 11:42 AM   #4
texasdave
texasdave's Avatar
1980 CJ7
Ooopsie! did we remove more wires than needed or mayhaps unplug or disturb other connectors in the process.
texasdave is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 12:32 PM   #5
thirstybob
Junior Member
Kinda what I was thinkin, hence my original question.
Unread Today, 06:59 AM   #6
thirstybob
Junior Member
I wanted to post my findings in hopes to help others with a similar struggle.
After extensive research, a post by John Strenk (thank you for your wisdom!) put me on the right path. He made mention that the brake light switch wiring goes through the turn signal switch before going to the brake lights. Low and behold, a poor wire connection on the lower steering column where the turn signal switch plugs in. All lights functional!
Thanks John and thanks Matt, for your response.
