#1 | |
Prop valve leaking
I installed a 93 YJ power booster and master cylinder in my 76 manual brake CJ. All that went fine. Now, however, I have a leak from the little plastic screw-in piece on the top of my prop valve. I changed to the plastic piece from the YJ prop valve, but it still leaks. I think this piece is just the electrical connection for the "no brakes" idiot light, so can I just seal the top hole with a brass plug?
Alcohol doesn't solve any problems, but then again, neither does milk. |
#2 |
The elec outlet on top is for the "no brake" light, and you should be able to seal with no ill affect. I sealed mine for the same reason and all works fine
1984 CJ7, 258, MPI, 4.0 head, Borla, 700r4, amc20 (detroit), Dana 30 (OX), 4.56 gears, Warn Hubs, Dana 300 with 4:1, 4.5 RE lift with 1" body, Bilsteins, dual battery, PS, PB, full cage, two dogs in the back.... |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
