Project Tub Swap... then Project Moab
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
Bicentennial Nickel
Here is the latest thing I put together.
It was just supposed to be a "tub swap", then the next thing you know New Frame Mounts NV3550 tranny swap hydraulic clutch new clutch parts new Tom Woods rear shaft new RE shocks new front bumper new winch body work paint job new family cage new rear seat new seat brackets new painless wiring harness new gauges in dash new center console New H4 headlights Line underneath and inside From the write up, you can see a ton of fab work as well to the frame. There was an awful lot done in a short time... took 3 tubs to get it there, but it is done now! http://www.certifiablejeep.com/curtisjeep/curtisjeep1.php http://www.certifiablejeep.com There wasn't much left of the tub once we tore into it, it was amazing that it even ran up to my place to do the work... took about 3 months to complete it, about 450 hours... it was a lot of long weekends and late nights! Let me know what you think. cb
#2 |
looks great bud
83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. |
#3 |
Bicentennial Nickel
Yup, had to finish it up before the little one arrived. The NV3550 is pretty nice I have to say... costs a bit more, but seems to shift nice, nice ride, hydraulic clutch is really nice too... YJ brake booster also... very nice.
cb |
#4 |
Wow! That was alot of work. It looks great. I am about to fix the same rust problem under my jeeps doors. You make it look easy! After having cars and jeeps worked on, you just put about $15,000 into his jeep! As always, great work.
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44 |
#5 |
Bicentennial Nickel
He got a good deal... and he realizes it.
the fab work, the frame repair, the body work, the welding, griding, sanding, all messy work, really does add up in time spent. I do realize why mechanics get 50+ an hour... an all in one guy should get that much as well... I however, did NOT! cb |
#6 |
nice. what kind of rockers are those?
#7 |
Bicentennial Nickel
Not sure exactly, they were on the Jeep when he showed up with them.
They are attached on top and underneath... kind of a PITA, but they do seem to function well. cb |
#8 |
when should i drop mine off??
#9 |
Bicentennial Nickel
Rates are going up with the next one... bring a big bag of money with dollar signs on it, or that money tree you have in your backyard... either works.
cb |
#10 |
i can do the bag thing with the dollar signs on it... it might be empty though
![]() this sbc swap ain't cheap...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
