#91 | |
I know you've heard it a thousand times this summer but I cant tell you how awesome this thread is. I am just starting my tub off restoration and you have saved me an untold number of hours. Please keep updating.
83 CJ7 ground up restore just begun. The chassis and drivetrain are in FL and the tub is in VA...this could take a while. POTENTIAL - The French word for "aint worth a s**t" |
#92 | |
anyway great project jc
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there" |
#93 | ||
#94 |
WOW, your doing a great job!!!!
#95 |
So I got to use a plasma cutter today. That was a mistake because now I want one.
I guess it's like a boat, always nice to have a friend that owns one. I have never been a fan of rockers being notched for the fender so those were first on the list to be fixed. These lips had to go: ![]() Nothing a cutoff won't take care of: ![]() Too bad the sheet metal is so darn thin. A few burn throughs: ![]() Welds cleaned up: ![]() ![]() Rockers laid up: ![]() ![]() Plasma cuts on the end: ![]() ![]() Thing looks like a crab: ![]() More soon. Drill mounting holes, weld bolts on, inner supports, etc.
#96 |
WTF is that?
For my knowledge base when I begin my body work - When you grind down those welds, are you be able to clean that up and paint over it, or will bondo or something of the sort still be required?
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift. AMC 20 Write Up In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles Coming Soon - CV Shafts, Welded Tubes, trusses |
#97 | |
#98 |
What an amazing rebuild. I can't wait to see the finished Jeep.
I just started tearing down an 83 CJ-7. With mine the tub is a total loss. Your thread is truely inspiring. Keep up the awesome work. |
#99 | |
#100 | |
No ideas on your primer. Papaja, thanks for the nice words. Let us know if we can help your 7 along ![]()
#101 |
Fatman,
Looks great. I am getting close to putting mine back together. I just have a little metal to metal work to do on the rocker panels. I should have been finished months ago. I am stalling hopefully you will begin your reassembly soon as I will probably be following along with mine at the same time
1980 CJ 7 yeah its Blue |
#102 |
Thanks Cajun,
I'm really looking forward to getting the pieces to paint. I'm hoping that this weekend will allow me time to Herculine the tub. My son has been scotch-padding the surface and I hope to flip it over so he can get the inside done by Friday. I'm trying to get all the fabrication & fit up stuff done before I paint color. I think I'll start a "Project Reassembly" thread starting with setting the tub for the final push towards completion.
#103 |
Fatman,
are you going to herc the tub prior to prior to painting? You are sending it out for paint..... I am working on trying it myself.........yes I agree with my wife on this one, I am a ******* I should have sent it out as well. anyhow, if you don't mind me asking what are you going to pay for your painting project.
#104 |
Cajun, I'm going to Herc before paint. After I get the tub back from paint I'll Mask off & do the final cut in. I'd rather have a small amount of paint overspray on the liner than the other way around.
My buddy Eric has a friend that is a painter. He did a nice job on Eric's Jeep and the price seems fair. I'm going to have him do the final prep and sand. At this point I'm ready to hand it over to a pro and get it back completed.
#105 | |
![]() Left: ![]() Right: ![]() Half an hour later had em sanded and rolling onto the rockers ![]() Cut some 7/16-14 grade 8's for studs ![]() squared up with the grinder ![]() welded up ![]() Lay out and drilling holes in the tub: ![]() ![]() Rocker ready to go: ![]() ... to be continued: .
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
