Quantcast Project "Tub" - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Project "Tub"
Old 09-17-2007, 08:45 AM   #76
Fatman
2008 CJ7
Originally Posted by high51977
Fatman, I have to say there is some really good info in both this and the cage posts. I still havnt gotten my Jeep home, but I am going to be refering to these posts when I finally do
Originally Posted by jatepper
Fatman,
WILL YOU RETIRE FROM YOUR BORING JOB...?
CAN I PAY YOU TO BUILD MY JEEP FOR ME!
I get more impressed at the work you two are doing everytime I check on your threads.
Thanks for keeping us all updated regularly on the rebuild.
-Jeremy
I fixed it for ya!
Thanks guys, glad this stuff helps
Fatman is offline   Reply With Quote
Old 09-23-2007, 02:46 PM   #77
Fatman
2008 CJ7
Mounted the bushwackers to the sides and fenders just long enough to then take them off and pull the tub.
Have some touch up welding to do then I'm going to spray the Herculiner after my son gets it prepped.
Hope to have it out for paint sometime in November.
inside clearence
Pulled the tub and put this in its place:
Back to it's resting place.
Old 09-23-2007, 02:53 PM   #78
Fatman
2008 CJ7
Oh, and I got some new toys to fit into the new dash:
I know, off topic!
Old 09-24-2007, 09:28 PM   #79
jeepster105
Fatman, are you spraying the herculiner inside the tub and on the underside? How many gallons did you buy? I'm trying to get an idea of how much I will need for my scrambler as the day of the spray is coming close and the tub will finally meet the frame again.
P.S. Everything looks great!
-Phil
jeepster105 is offline   Reply With Quote
Old 09-24-2007, 09:57 PM   #80
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I shot 1 gallon inside my CJ5 tub and it was perfect.. nice and thick. If I were gonna shoot a CJ8 inside and underbelly, I'd probably pick up 3 gallons. About 1.5-2 gals inside and the rest underneath.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 09-25-2007, 07:04 AM   #81
bdmonist
WTF is that?
bdmonist's Avatar
inside clearence
When you trim it, will you intrude where the inside wheel well ties into the body? If so, more sheet metal work required to tie it back in?
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
AMC 20 Write Up
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline   Reply With Quote
Old 09-25-2007, 07:16 AM   #82
Fatman
2008 CJ7
-Phil
Phil,
I'm going to shoot the inside, underside and inside of front fenders. I'm thinking about the engine side of the firewall but can't get a clear answer on how the product holds up to heat.
I bought (2) gallons form Ace Hardware: LINK Herculiner Kit 8105173 HCL0B8
And I bought a quart for the sprayer from car quest: Herculiner Spray Can QT HCL0B4
I also bought (4) quarts of Herculiner UV Protectant Top Coat HAL1B7
I bought enough that once I'm done I should have enough to shoot the bed in my F150, if not then I'll just order more.
Old 09-25-2007, 07:30 AM   #83
Fatman
2008 CJ7
Brian,
In that pic, I've already trimed over an inch off the rear of the fender and rolled the edge over against the fender well. I'm not going to cut out anymore than what's shown.
I am going to make the 1 1/4" rolled edge at the bottom flush with the rest of the fender and tub. I'm making up some 3/16" rocker panels and will run them full length and under the flares.
Of course I'll have pics of those too.
I tacked in some 1/2" conduit inside the fenders to run wires for lighting, aux lights, elect fan, etc.
Old 09-25-2007, 05:02 PM   #84
CJClyde
Sweet idea on the conduit!!! Another point for my notes.
1984 CJ-7, 4" Trailmaster, 31's. Future plans include complete rebuild with SBC 350, Dana 44 front, Ford 9 inch rear, and SOA with highsteer.
CJClyde is offline   Reply With Quote
Old 10-02-2007, 05:03 PM   #85
Fatman
2008 CJ7
Well if this don't beat all.
Went to pick up my steel and they cut my indicator holes too long on my dash.
Oh well, the new one will be ready tomorrow.
I bet once I lay out my gauges they'll be real eager to cut em for me.
Went 16ga for the dash, should hold up well.
Good news is I also got my rockers done. Going to mark the tub and weld 7/16" thread to the inside of the rockers so I don't have any bolts showing. Rockers are 3/16 Plate steel 5" to the brake and 2" under. Overall 60"
Old 10-02-2007, 05:39 PM   #86
vtjeeps
cage
hey did u make that cage or buy it
The insurance company said its high RISK but i said no no its full width ...
vtjeeps is offline   Reply With Quote
Old 10-02-2007, 05:49 PM   #87
Fatman
2008 CJ7
It's a kentrol kit. I added quite a bit to it though.
See this thread:
http://www.jeepforum.com/forum/f8/project-cage-450100/
Old 10-03-2007, 08:51 AM   #88
aero mech
aero mech's Avatar
1980 CJ7
Teaser told us you got your rockers done but didn't post any pics you sorry dog!!!!! Ya going to add any speakers behind the dash? jc
80 CJ-7 Straight six,comp cam,4.0 head, cherokee header, DUI distributor, Affordable FI TBI ,4.10's wide track amc 20 aussie locked and trussed, Dana 30 aussie locked, PSC steering box, 4.5 RE lift, twin sticked dana 300 with Lo max 4to1 35"STT'S ON DC-1 "It's getting there"
aero mech is offline   Reply With Quote
Old 10-03-2007, 08:53 AM   #89
aero mech
aero mech's Avatar
1980 CJ7
ya going to add any speakers behind the dash. Nice work so far. jc
Old 10-03-2007, 08:46 PM   #90
Fatman
2008 CJ7
What are you talk'n bout? Don't you see em lay'n right there "done" in the back of my truck?
I've got to bolt them up tomorrow, think I'll take the day off from work and get some of this stuff finished up, then I can get you guys some pics.
I did get the 2nd new dash picked up today... AWESOME!
Glock Forum
