Quantcast Project "Tub" - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Project "Tub"
Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFGWant a weekly chance to win $50 in Jcr bucks?
Old 06-28-2007, 08:09 PM   #1
Fatman
2008 CJ7
Project "Tub"
Ok, so I've been putting this off for a while. But the rust on the Jeep has to GO!
Started pressure washing the muck off a few weeks ago and am in the process of sandblasting the thing clean.
I've got four areas in the floor I'm going to weld in new panels (16 ga) and some rust will be cut out on the passenger side panel.
Also in the body work I'm going to fill every hole that will not be used again, i.e. top snaps, antenna, tire carrier, floor drain holes, and a bunch in the firewall.
So for the next several weeks (I only get to work on this at night and weekends) join me as I rip this thing open and replace pieces of metal.
Feel free to comment, suggest, recommend, whatever with what has worked (or not) for you.
This is what I'm starting with:
Cleaned up a lil bit:
The drivers side has a cheap 20 ga piece of junk that was arc'd in. Going to have to take the cut off to that:
Built a frame to roll the body around on. This helps a lot:
Lots of grime:
Rust is bad, mmm k...:
Future owner work'n hard for the money:
Fatman is offline   Reply With Quote
Old 06-28-2007, 08:19 PM   #2
bdmonist
WTF is that?
bdmonist's Avatar
What are the coating plans? Herculiner, Line-X, plain ol' paint?
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
AMC 20 Write Up
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline   Reply With Quote
Old 06-28-2007, 08:23 PM   #3
Fatman
2008 CJ7
Got the two rear spots measured up and cut out last weekend.
Also started filling in a lot of the small holes.
Weather has been too nice the last couple of days so I've been riding the Harley to work, but I did pick up a 36 x 48 sheet of 16 ga on Tuesday.
Had them cut it in half for me.
Filling top snap holes:
Tire carrier holes filled:
Laying out for the cuts (used a sawzall on the body):
Cut:
Old 06-28-2007, 08:25 PM   #4
Fatman
2008 CJ7
Bottom of tub, firewall, and inside of tub I'm going to spray Black Herc.
Body's going Ford Truck Yellow!
Old 06-28-2007, 08:33 PM   #5
Fatman
2008 CJ7
So the steel came home:
Marked my two rear pieces for the roll bar area:
Few cuts with the 7" cut off blade (thanks BESRK) :
Five minutes with the vice and a 4# hammer & I've got the first piece ready:
Yeah, that's going to work out fine:
I'll bend up the other side tomorrow and hope on Saturday to weld these in place.
Old 06-28-2007, 09:22 PM   #6
Mr.Crowley
1980 CJ7
just something to think about..anytime I weld in steel thats hidden from coating like under that body mount channel I like to spray it with weld through primer..Its a cold galvinizing primer that you can weld through with no ill effects..wont burn with the heat...other than that great job..and good to see you have your son helping you out..times to cherish
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
Old 06-30-2007, 07:25 PM   #7
bdmonist
WTF is that?
bdmonist's Avatar
Saturday's almost over, what gives?
AMC 20 Write Up
Old 06-30-2007, 07:40 PM   #8
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Looks like you're on the right track. Doing a good job so far. Ditto on the weld-thru primer.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is online now   Reply With Quote
Old 06-30-2007, 08:21 PM   #9
Fatman
2008 CJ7
Patience, patience...
Guys, thanks for the help and suggestions!!!
Ok, Friday (at work) I search the net for this "cold galvanizing primer" and find it at Fastenal. The stuff's not cheep. Confirm they have it in stock, and pick up a can after I get off work. (thanks Scrambled)
Since my family is in Virginia for the weekend I'm not going to hang around, so off to N. Raleigh to help a friend try to bend some 2" pipe for his engine cage. He has some nice steel but his H/F hydraulic bender was not fun to use.
We decide instead to weld some D-ring tabs to his bumper and then add side mounting plates to wrap the frame. Got home bout 12:45 am, misplaced my wallet and finaly crashed.
Today allowed me to get to Lowes, get a new 4.5" grinder, back to the house and then leave with another friend to look at new Electra glide Classics and Street glides in Fayettenam and Ashboro to replace the one he totaled last month.
No luck on the on a replacement, but enough time left in the day to fire up the borrowed sand blaster and make a mess, bend another piece of steel, drill some holes for the roll bar bolts, and spray some zinc primer on the two pieces and the inside of the channels.
No welding on my own rig today, I'll set the two pieces I've got ready tomorrow and weld em in tomorrow once my boy gets home.
Few pics of todays non production:
Old 07-01-2007, 11:39 AM   #10
Fatman
2008 CJ7
With the drivers side cleaned up I pretty much lined up the new piece, set a few pop rivets and welded er up.
One inch fender washers are going to work perfect to fill all of the drain holes:
Pass side lined up, pop rivets to hold front, few tacks and the game is on
Trim the back edge
Cleaned up
Some more zinc primer
Inside tub shots
Tool collection point
My buddy Miller
Old 07-01-2007, 12:20 PM   #11
RnEmOvr
Never Forget
RnEmOvr's Avatar
looking good
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 07-01-2007, 07:53 PM   #12
Fatman
2008 CJ7
Originally Posted by rnemovr
looking good
Thanks! progress is good.
Few more pics from today:
I filled 7 of these today, the rest I'll have to get once I turn the tub back over:
What a sorry repair the PO did, left the old mess to collect dirt and mud, and covered it with a 20 ga piece of tin.
Cut this out with a nibbler, worked well, nice tool. Going to have to cut out a lot more and remove the repair piece:
Old 07-17-2007, 11:10 AM   #13
Fatman
2008 CJ7
Well we finished sandblasting the bottom of the tub Sunday. (my son's been at wrestling camp, and I have not been motivated) flipped the tub and started brushing on the rust neutralizer. Welded up the top side of the roll bar area repairs and sprayed some zinc primer.
Hope to cut out the front floor boards this weekend and make patterns for the new steel.
More pics soon.
Old 07-17-2007, 12:09 PM   #14
AggieCJ
Pretty cool, looking forward to seeing the rest of it come together
AggieCJ is offline   Reply With Quote
Old 07-17-2007, 04:46 PM   #15
Fatman
2008 CJ7
few pics:
Glock Forum
