Project: SBC 350 - Page 7 - JeepForum.com
post #91 of 103 Old 02-18-2011, 11:47 AM
swatson454
1983 CJ7
ms198,
You can get a whole lot done with a solid/flat cam if it's well-spec'd. I really like solid rollers but they're not for the faint of heart or light wallets.
If you can give us some details on the Jeep and the heads, I'll see if I can help you out with cam specs and a good engine combo.
Shawn
Edit: You may want to consider a new thread rather than us stomping all over Fatmans.
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #92 of 103 Old 02-18-2011, 03:27 PM
ms198
ok i posted a new thread in the engines and drivetrain section. if anyone can give me some more help i would appreciate it.
ms198 is offline
post #93 of 103 Old 02-18-2011, 07:06 PM
swatson454
1983 CJ7
I posted over there but you sure might get a whole lot more traffic and some other opinions/ideas for your build if you were to move it over here.
Shawn
post #94 of 103 Old 02-18-2011, 07:11 PM
yahwhy
1982 CJ7
fatman, did you have any plug wire clearance problems with the angle plug heads, and the shorty hedders? i just bought a like new set of dart iron eagle 64cc angle plug heads, and i'm worried about clearance with my shorties,were you able to run all plug wires with a 90 degree boot? thanks
yahwhy is offline
post #95 of 103 Old 02-19-2011, 11:56 AM Thread Starter
Fatman
Fatman's Avatar
2008 CJ7
No clearance issues at all. Boots all fit w/o any problems. Plugs all come out w/o any special sockets. You'll like those dart heads !
Thread Links:
Fatman is offline
post #96 of 103 Old 05-22-2011, 01:06 PM
SpringPro
1977 CJ7
That engine looks awesome. Just a quick question for you. Why did you go with the Ford Starter Solenoid instead of the Chevy Solenoid? I am looking into the Chevy swap right now and trying to learn as much as possible. Your build has offered alot of insight. Thanks. Also, is that a battery disconnect on the firewall below your battery.
SpringPro is offline
post #97 of 103 Old 05-22-2011, 07:46 PM Thread Starter
Fatman
Fatman's Avatar
2008 CJ7
First off, thank you very much. It means a lot that others get something outta this info being shared.
Chevy's have always had a bad problem with starting a hot motor .... actually it's got zip to do with the motor and everything to do with the chebby solonoid failing. I've been doing remote Frod starter set ups since i learned of it in the 70's. Header heat, lack of engine bay venting all play hell on the Chev starters
It is. Ssshhhhhhh. now only 653 people know. Just a simple measure to stop an amature thief, and save a jeep from a roll over fire on the trail ...
Thread Links:
Fatman is offline
post #98 of 103 Old 05-22-2011, 08:07 PM
SpringPro
1977 CJ7
I was thinking that was the reason but wasn't sure. I posted another thread earlier and was hoping that you would chime in. I am looking at the 350 swap and was going to use a crate engine to start with. I am looking at a ATK crate engine.
http://high-performance-engines.com/...duct_Code=HP32
I was thinking along the lines of Performer intake (air gap?) 600 or 670 cfm holley, and MSD HEI ignition. What are your thoughts?
post #99 of 103 Old 05-22-2011, 08:39 PM Thread Starter
Fatman
Fatman's Avatar
2008 CJ7
http://high-performance-engines.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=ATK&Product_Co de=HP32
ok .. first, I know someone is going to get their tits twisted over this but I'm not a fan of the gen iii motors. The ls and vortec stuff flows well and can make good numbers, but I'm just old school. Plus I can make higher HP for less $$$ with good iron and good heads.
So ... If buying a snap in works, go for it. If you have a good machine shop, you can give life to a 70's early 80's 4 bolt and make the project yours .
Thread Links:
Fatman is offline
post #100 of 103 Old 05-22-2011, 08:59 PM
SpringPro
1977 CJ7
Thanks for the reply. I will keep looking but I have not found a good machine shop around me so far. Thus the reason for the crate motor.
post #101 of 103 Old 12-06-2011, 09:09 PM
cdmiller2
1981 CJ5
I know its an old thread but did the headers clear the front driveshaft fine? The number you posted comes up as for a yj on summit.
cdmiller2 is offline
post #102 of 103 Old 12-07-2011, 06:56 PM Thread Starter
Fatman
Fatman's Avatar
2008 CJ7
No issues with the drive shaft clearance.
Ah Yes ! the infamous square light jeep with the stock bowtie 350 !
Thread Links:
Fatman is offline
post #103 of 103 Old 12-05-2015, 08:38 PM
Mavsjeep13
Ok so i am doing a 350 small block swap in my YJ and i need some help in looking for the right transmission for it, i am looking for one to withstand both high torque as well as high horse power. That being said im making mine into a crawler so i need something with a good gear ratio, but that can be worked out after if need be. i would prefer a 5 speed manual transmission and then i will have to find a new transfer case to top it off because i have already purchased front and rear axles. and as far as my budget is concerned there really isnt one, i would prefer something that requires as little maintenance out side of servicing it.
Mavsjeep13 is offline
350 , horse power , over kill , sbc , small block chevy
'82 Project CJ7 Kdozier Jeep CJ Forum 69 10-19-2013 09:17 PM
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 11:38 AM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 05:53 AM
project 77 CJ5 atom73 Jeep CJ Forum 0 03-05-2007 07:20 PM
My CJ project paraman72 Jeep CJ Forum 1 05-24-2005 06:50 AM
