Project: SBC 350 - Page 4 - JeepForum.com
post #46 of 103 Old 04-21-2010, 09:08 PM Thread Starter
Fatman
Fatman's Avatar
2008 CJ7
Jeepman, got it from a buddy of mine.
It's a Lakewood 15080. Strong and heavy !
Lakewood :: Product Details
Thread Links:
Fatman is offline
post #47 of 103 Old 04-28-2010, 03:39 PM Thread Starter
Fatman
Fatman's Avatar
2008 CJ7
Had time to build the trans crossmember.
Will make a hard tab off the rear brace for a torque stop and directly mount it into the D300.
Have to cut a skid, probably use 1/4" plate and fasten it to tabs
Catalytics and Flowmasters are here and waiting to be installed.
Still need to find a shop to cut my front drive shaft adn re-tube the rear.
Once the exhaust is finished. I can cun the fuel lines.
Few pics:
Thread Links:
Fatman is offline
post #48 of 103 Old 04-28-2010, 06:36 PM
jatepper
Why wouldnt the old skit plate work?
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #49 of 103 Old 04-28-2010, 06:45 PM
Coiz
1979 CJ7
That tab your transmission mount is attached to would make me a little nervous. Is it that stout or should you add a couple gussets on the ends toward the top of the bar?
Everything is looking great.
Mike
Coiz is offline
post #50 of 103 Old 04-28-2010, 07:24 PM
lifeisgd
Looks like you will be back up and running sooner than I will. Have had major issues with "old blue" due to the head gasket issue and finally am breaking down for a complete re-build from top to bottom. For anyone doing a 4.0 head swap on a 4.2 make sure you use a 4.0 head gasket....
lifeisgd is offline
post #51 of 103 Old 04-28-2010, 07:30 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Looking good Dave!
One thing I did notice... you're using poly bushings both at the ends of your tranny crossmember, and at the TC mount itself.
It may work fine for you but I used a similar setup on my old CJ5 (with a SBC and Turbo 350) and ended up cracking the tranny case because the double poly mounting system (for the tranny/tc) flexed more than the engine mounts (which were also poly bushings like yours). Granted, it cracked the tranny when I landed on the front tires at full throttle after the Jeep "hopped" during a steep climb.
Might want to keep an eye on it.. maybe add a bar to limit torque induced roll... something similar to the stock D300 torque bar.
Of course, you know there's only one sure fire way to check the system right?... it involves floating valves and side stepping the clutch..
BESRK is offline
post #52 of 103 Old 04-28-2010, 09:03 PM Thread Starter
Fatman
Fatman's Avatar
2008 CJ7
1/4 inch plate, it's stout.
The 1/4" skid plate will back it up.
Originally Posted by BESRK View Post
Looking good Dave!
I was looking at controlling torque roll with a 1/4" bracket welded off the rear crossmember and bolted to the back of the shim cover of the front output shaft.
I could always just throw on the stock torque arm and weld in another tab, cool thing is, it'd be covered by the skid plate. ... thoughts ?
hell yes, that sounds like your cam break-in procedure !
Thread Links:
Fatman is offline
post #53 of 103 Old 04-30-2010, 05:49 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I think either method would work for you..
This thread has me pumped! I think I'm gonna roast my back tires this weekend in tribute.
BESRK is offline
post #54 of 103 Old 05-04-2010, 04:53 PM
Stan99
1978 CJ7
Man if I didnt enjoy falowing your builds, I would really hate you! Youre gona have this thing rebuilt for a second time before Im done with my first build.
Great Job!!!!!!!!!!!!!!!!!!!!!!!!
1978 Jeep Cj7 Soa, Shackle Reversle, 36x13.5x15 Irocks, 4.5 Stroker MPI, Dana 300 twin Sticked, 4.88's
Stan99 is offline
post #55 of 103 Old 05-04-2010, 08:37 PM Thread Starter
Fatman
Fatman's Avatar
2008 CJ7
Thanks Stan, stay the course, you'll be there in no time.
Broke a finger Friday helping a friend work on his dash. Using the tube notcher and the bit hung up, swung the drill around and did a number on my hand.
Was able to finish welding the tabs on the rear cross member and set the skid plate. Can't hardly even hold anything w my right hand. Tried to put a coat of spray down but to painful to push the trigger.
Will make some progress one handed. Trying to get things tightened up so I can take it up to the exhaust shop.
Thread Links:
Fatman is offline
post #56 of 103 Old 05-04-2010, 09:26 PM
Skerr
Looks really clean. Very nice work.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #57 of 103 Old 05-10-2010, 01:24 PM Thread Starter
Fatman
Fatman's Avatar
2008 CJ7
Coiz, you'll be glad to know I beefed up the bracket ! Good advice,
Got my Flowmasters finished, put Magnaflo CATs in front of them. Guys at Bob's did a great job.
Finished up the fuel system last night, Check valve to filter to Holley blue to Holley FPR.
Need to add fluids, prime the oil pump, set the dizzy and she's ready to run.
Still looking for a good driveshaft in the 24 - 27" field.
Thread Links:
Fatman is offline
post #58 of 103 Old 05-10-2010, 01:40 PM
swatson454
1983 CJ7
That's a pretty slick throttle linkage set-up.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #59 of 103 Old 05-15-2010, 03:54 PM Thread Starter
Fatman
Fatman's Avatar
2008 CJ7
Well she runs ! STRONG !
Did the start up Thursday night, ran it for 20 min @ 2300 to break in the cam, got the timing set and everything checked out great.
Shut it down and came back to it 30 min later, would not start ? Quick trouble shoot and i determine it's the MSD ignition box. So I pull the box and wire the coil to ignition, she fires back to life. Trigger testing of the box reviles the box is dead. WT*, 20 min on the box just pisses me off. Got a RMA # from MSD on Friday so back it goes. Runs perfect in HEI mode w/o the ignition so I'm debating if the 6A goes back in when returned.
Got the replacement DS in:
Mount brackets for the check valve and fuel filter:
I shot some video of the start up, unfortunately the sound is not being picked up on the camera.
Pulled the Ign box:
Thread Links:
Fatman is offline
post #60 of 103 Old 05-15-2010, 04:05 PM
Coiz
1979 CJ7
Good call! That looks exactly like what I was picturing. That's just a whole lot of weight and torque sitting on that tab to just be hanging out there like that.
Everything looks outstanding as usual. I'll bet that thing is a hoot to drive.
Mike
Coiz is offline
350 , horse power , over kill , sbc , small block chevy
'82 Project CJ7 Kdozier Jeep CJ Forum 69 10-19-2013 09:17 PM
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 11:38 AM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 05:53 AM
project 77 CJ5 atom73 Jeep CJ Forum 0 03-05-2007 07:20 PM
My CJ project paraman72 Jeep CJ Forum 1 05-24-2005 06:50 AM
