Quantcast Project: SBC 350 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Project: SBC 350
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 03-30-2010, 08:47 PM   #1
Fatman
2008 CJ7
Project: SBC 350
I’ve had this in the works just as soon as I decided the 258 / 4.0 head / HEI /Borla header / Crane cam motor was just not enough. Finally sold off the last of the great blue 4.2.
So my goodest friend let me work off some debt for his spare 0100 4 bolt main 350. History on the block was from a 69 Vette. Good news there, but somewhere along the lines it lost the Vette body and the heads as well.
This isn’t going to be your typical pull a motor from the junk yard and bolt it in to the Jeep thread. I’ve got my T18a all set up for the swap as well as the D300 built up as well.
So I strip the block down after it’s sat in my shop all winter, and take it up to the machine shop for the once over. Turns out it’s been .030’d already and run hard as hell since then. Foreman asks if I want to find another block or go .060. ….. .060 it is. Sentimental value here, this block was basically a gift and I’m going to make it work. So we square it, check the deck, and measure up the rest. Turns out the crank is way out of spec as well. So I order up a new crank, main and rod bearings, new set of .060 pistons, and a host of other goodies while I’m at it.
Summit has everything to my door in three days so I’m back up to the shop with my pistons so Foreman can bore it and hone it.
Two days later and I’m picking up my block and my pistons are pressed in to the rods.
Back at Casa de Fatman, I get out the aircraft paint remover and kill this thing with a good layer of paint be GONE ! Brake cleaner, compressor running full time and my new lil brushes, I have this tang el spotless and ready to play. Five coats of Cheby orange and it’s look’n good. An hour of thread chase'n and we are ready to build !
New RMS upper installed and sealed in place, lubed up w waterproof. One new crank washed down and installed w new set of std bearings. Plastigage reads .002 across the caps, so feeling good. Pop the caps off, a good dose of oil to lube things up, bottom half of RMS sealed up and torque these caps down.
Ring the pistons, then clean em up again, set the upper bearings on the rods, a good coat of oil on the skirts after a 60 second dip in the oil bath, and we are thumping pistons into the holes. Plastigage again and pleased with eight readings of .0015 to .002. Clean up the journals and oil em up. Five cycles of the crank and everything feels A+. Torque to rotate is a consistent 32 #’s.
Wash down of the cam, bit o assy lube on the lobes and oil up the bearings and we have our new cam slid in place without a bump. Lil bit mo assy lube on the lifter flats and a dip in the oil bath and 16 tappets are ready.
Tomorrow I’ll set the heads, push rods, rockers, water pump, 710 pump, intake, oil adapter, and anything else I can get to. Sure, it won’t take long to work up to whatever it is I forgot to order.
Pics, ... you knew they were coming
On the way to the shop
Back at my shop and cleaned up:
Fresh paint:
Santa comes early (or late ?):
Like a candy store:
Compressed:
Half:
Udder half:
Cam in place:
Dropping tappets:
Fatman is offline   Reply With Quote
Old 03-30-2010, 08:54 PM   #2
jcal73
WAY TOO FAT FOR MY CJ5
jcal73's Avatar
1979 CJ5
I"ve been waiting for this!
Subscribed!
Jeff
Originally Posted by Shiftace View Post
Chrome because I am a welder and welders are like crows. We are attracted to shiny crap.
Our Little Links
1979 CJ5
1978 Cherokee Chief
CJ5 Dream/Build Sheet
Cherokee Chief Dream/Build Sheet
Our SBC Swap
How we made a Fan Shroud
jcal73 is offline   Reply With Quote
Old 03-30-2010, 09:01 PM   #3
Fatman
2008 CJ7
Subscribed!
Jeff
I just found your thread. Looks like a nice job you've done. And what a plus to be able to do it with the boys !
Old 03-30-2010, 11:59 PM   #4
nedmoore
nedmoore's Avatar
1982 CJ7
looking forward to your progress...
nedmoore is offline   Reply With Quote
Old 03-31-2010, 01:28 AM   #5
airtime262
1979 CJ7
I just pulled up a chair myself...this is what I want to do also, however, for now it pains me, but I dont have the time or money to go your route. I know my 350 runs, so just the basic intake, carb and dress up for now. Carry on Fatman, the drool is starting....
I now live vicariously thru you.....it's cheaper that way
Why do they call them apartments when they're so close together??-Steven Wright
"A parent's only as good as their dumbest kid. If one wins a Nobel Prize but the other gets robbed by a hooker, you failed."
airtime262 is offline   Reply With Quote
Old 03-31-2010, 05:52 AM   #6
Scooter402
Nice choice on heads! I love building new engines...that's half the fun of the whole deal!
What do the cam specs look like? I KNOW you dint stick no stock bumpstick in 'ere...
Scooter402 is offline   Reply With Quote
Old 03-31-2010, 11:34 AM   #7
TRex
1979 CJ7
Always the consummate craftsman, Fatman! Can't wait to follow this one! Whoohooo!
Is that Chevy orange a metallic? The second to last pic makes it look deep and glossy. Me likey!
[B][SIZE="4"][COLOR="DarkOliveGreen"]Brand New 1979 Jeep CJ7[/COLOR][/SIZE][/B]
Completely rebuilt from the ground-up with the help of all of you. Thank you!
[SIZE="1"]AMC 304 | T-150 | 4.10s | D30 Front/D44 Rear | 2.5" w/ 35's | Holley 470[/SIZE]
[B].: [URL="http://www.jeepforum.com/forum/f8/1979-cj7-build-project-trex-935022/"]Follow My Build Thread![/URL] :.[/B]
TRex is offline   Reply With Quote
Old 03-31-2010, 11:42 AM   #8
SonicR1
SonicR1's Avatar
Did you stroke it too???
... I guess I'm gonna have to fix that too…….
1974 CJ5 BUILD THREAD
1974 CJ5 BUILD PHOTOS
Bumble Bee The TJ
SonicR1 is offline   Reply With Quote
Old 03-31-2010, 12:25 PM   #9
243
NOT a Web Wheeler
243's Avatar
1983 CJ7
Good, I got in on the first page!
Looking great
1983 CJ-7, 258, T177, D300, 3.54’s and 32” KM2’s
Many thanks to those with contributions to my build:
twoleos617, Jim1611, Yellow85CJ, kickingprop, CJnPA, Fatman, Grewel, -boom and VACJ7...oh crap, and EXPOSED too!!!
Money Pit >>>http://www.jeepforum.com/forum/f8/daves-83-cj7-build-891652/
...a jeep ensures you don't have a drinking, drug or woman problem: always dirty, broke and tired. "ACAD_Cowboy"
243 is offline   Reply With Quote
Old 03-31-2010, 12:28 PM   #10
hookedupinc
I stroked it...
Build this thing bro...
"Aw, jis taws a D-sisty aNNa SEE-fortene in air, an-U kin hit da mudHO wit me and Bubby dis weakin."
http://www.jeepforum.com/forum/f12/project-jevy-984905/
hookedupinc is offline   Reply With Quote
Old 03-31-2010, 12:51 PM   #11
Fatman
2008 CJ7
Thanks, I have always wanted a set of these angle plugs.
Some specs below.
Tanks Rex, just regular Plasti Cote High temp, hope it holds up.
Nope, When I had the decision to get the new crank, I thought about it, but it was a passing thought.
Looking great
Welcome Dave, I like watching your build as well.
At least I can keep an eye on my old harmonic.
Originally Posted by hookedupinc View Post
I stroked it...
hookedupinc, you better go wash those [Richard Beaters], no one is going to shake your hand.
Specs on the build are as follows, Included Summit's #'s for the hell of it.:
Comp Cams Xtreme Energy Cam Kit
Gross lift .462 In .480 Ex
Duration 262 In 270 Ex
Lobe Separation 111.0 Going to set it at Zero advance.
CCA-CL12-239-3
Steel Internally Balanced Crank
Stock SBC Specs 3.480 Stroke
SES-3-48-05-000
Speed Pro TRW Pistons Hypereutectic Flats 4.060in
TRW-8KH631CP60
Proform Gear Drive
PRO-66917C
All bearings are Federal Mogul A-series Bi-metal
FEM-2555CP ROD BEARING
FEM-4663MA MAIN BEARING SET
FEM-2100M CAM BEARING
FPP-2912 REAR MAIN SEAL
Edelbrock Angle Plug Heads
EDL-60999
Edelbrock 7501 Performer RPM Air-Gap Intake Manifold
EDL-7501
Summit OEM Harmonic 8”
SUM-161358
Short Water Pump High Volume
SUM-311005
Summit 1.5 Ratio Roller Rockers
SUM-G6910B
Holley 670 Avenger Carb Single Feed
HLY-0-90670
MSD HEI Distributer
MSD-8474
MSD Ignition 6200 - MSD 6A CD Ignition
MDD-6200
Hedman Headers Elite Shorty’s
Steel Thermal Coated
HED-69648
K&N X-Stream Air Flow 14” Wide 4”Tall
Part Number: KNN-66-3020
Everything else is pretty much cosmetic
Old 03-31-2010, 01:08 PM   #12
hookedupinc
Old 03-31-2010, 01:09 PM   #13
kickingprop
No FunHaters Allowed!
kickingprop's Avatar
what kind of cost are you looking at overall just on the motor and accessories for this build? I'm looking to throw something similar into the Scout 800 I'm going to build
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline   Reply With Quote
Old 03-31-2010, 01:19 PM   #14
hookedupinc
SBC in a 'Scout'? Shame on you.
Old 03-31-2010, 01:37 PM   #15
kickingprop
well if you or anyone in the houston area has an IH 304 or 345 they arent using I'd gladly take it off their hands and keep it all IH...but I havent seen much available lately...and to say SBC is plentiful is an understatement.
I'm 90% sure the 304 currently in there is toast...
1985 CJ7 Project
350, horse power, over kill, sbc, small block chevy
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
