Project "Reassembly" - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Project "Reassembly"
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 03-16-2008, 07:05 AM   #61
Fatman
2008 CJ7
Originally Posted by Pacfanweb View Post
Dave, looking good there. Almost warm enough for the Herc job now.
It's 48* at 9am. I'm going to go out about 10-ish and wash it out with "Dawn". (gotta be careful with our current water restrictions)
If it gets close to 64* and I can get the tub dry enough, I'll get the primer put down.
Eric may be coming down around noon, you're more than welcome. Just not sure what we'll be able to get done with the temps. Give me a call.
As for the filter thing, these days it's pot luck with anything you buy.
Fatman is offline   Reply With Quote
Unread 03-16-2008, 08:27 AM   #62
supraman1990
1980 CJ5
It hasn't been as warm down there as it has up here has it Dave? It was 70+ 3 days this week up here. I sprayed some of my last stuff actually, and it set up great.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline   Reply With Quote
Unread 03-30-2008, 01:12 PM   #63
Fatman
2008 CJ7
We got that same stretch of warmth, Friday was in the 80's. Today's not going to hit 45*
Got some other stuff done, can't do anything on the interior, so...
New plastic thinga majiggers for the clutch thina mabob
Drilled and added a spring to keep the actuater rod in place
Put in the rear cage tie-ins
New O-rings and connected the PS lines
Put the Vanco Brakes in place, this was a waste of $, bout an inch too wide.
SS battery tray
Gotta go up to the shop Monday and size some Russell Hardware for the Fuel pump, TBI, and return lines
Unread 03-30-2008, 02:07 PM   #64
fatterman
fatterman's Avatar
the vanco brake assembly was too wide? or the air filter?
fatterman is offline   Reply With Quote
Unread 03-30-2008, 02:57 PM   #65
Fatman
2008 CJ7
it'll fit, just not with the K&N
I'm wondering if I'm going to need to put a solid motor mount on the pass side to keep it from flexing. I've got about 1/4 - 1/2" of room between the linkage
Unread 03-30-2008, 03:06 PM   #66
Mr.Crowley
1980 CJ7
either a solid mount or a turn buckle from an engine bolt to the frame somewhere..I have used a length of chain on drag cars without solid mounts...Like the 77 trans am I'm slowly building for Pinks..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
Unread 03-30-2008, 03:52 PM   #67
Fatman
2008 CJ7
Vanco Brakes
Ok, I'm kinda concerned that I've got the wrong Bracket with my brake booster.
I know someone is going to pick up on it, yes I know the threaded extension is up side down.
The flexible rubber piece does not reach the firewall and I didn't get any type of gromet to fill this area?
When I but the two components together and align the brake turn out to match the clutch stop I have over an inch of thread.
This is about equal to the distance of the rubber away from the firewall.
Close ups:
This showes it well:
Am I missing a piece or do I have the wrong brackets?
Unread 03-30-2008, 04:37 PM   #68
high51977
if I had to venture a guess I'd say you are missing a grommet of some sort (I am just basing that on my chebby S10 though)
Play by the rules you're gonna miss all the fun
high51977 is offline   Reply With Quote
Unread 03-30-2008, 05:12 PM   #69
jatepper
jatepper's Avatar
Hmm, weird. Why didnt you just do the YJ swap instead of the Vanco system? Nothing wrong with Vanco, just curious.
1985 Jeep CJ-7
Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage.
USMC 1999-2004 Semper Fi!
Hood Hi-Lift Jack Mounts for CJ/YJ/TJ/JK
Torchmate CNC Plasma Table Build / Projects
The Target Man, LLC - AR500 Shooting Targets
jatepper is offline   Reply With Quote
Unread 03-30-2008, 05:42 PM   #70
Havasu Living
Havasu Living's Avatar
1980 CJ7
I have been waiting months to see those steps. Functional and something a DIY can do.
BTW sweet project.
80 CJ7 5.0 T176 D300 D30 AMC 20 York OBA
Havasu Living is offline   Reply With Quote
Unread 03-30-2008, 05:43 PM   #71
cshutchinson
Box Man
cshutchinson's Avatar
Man, I am trying to catch up with you, but you are moving on with the reassembly! Good job. Your pictures are going to be very helpful.
1985 CJ7 / SBC 383 / D300 / NV3550 / 35 SSRs
Hutch's 1985 CJ7 SBC 383 Frame Up Rebuild
cshutchinson is offline   Reply With Quote
Unread 03-30-2008, 05:54 PM   #72
NWA_CJ7
1983 CJ7
What are the brackets you have now for, it looks to me as if there about an 1 1/2 to long themselves.
83 CJ7 AMC 360, nuttered & team rushed. Dana 44 rear geared & locked, Dana 30 front geared & locked Dana 300 T. Case 4" Tough Country Lift, 1" daystar body lift, 1/2" shackle 35x12.50x15 MT MTZ's on MT classic 2's, Besrk Bumpers, Genright Tube Fenders
NWA_CJ7 is offline   Reply With Quote
Unread 03-30-2008, 06:30 PM   #73
Fatman
2008 CJ7
No offense to any one with a CJ running YJ brakes, but I was not about to put junkyard brakes on something my family will be driving.
Van has a hell of a good reputation, nuff said.
BTW sweet project.
Glad you like, nice for DD, easy to pop off when it's LOW - GO time.
Let's get that 300 back together, let me know if I can help
They are 3 5/8" from booster to firewall.
2" would be perfect.
Unread 03-30-2008, 06:42 PM   #74
spk454
1983 CJ8
quick note on the vanco, according to van the stock booster adds 1000lbs of boost, yj is 1200, vanco is 1600 so there is an actual difference as well as it being a new unit...
spk454 is offline   Reply With Quote
Unread 03-30-2008, 06:51 PM   #75
NWA_CJ7
1983 CJ7
Can you not call vanco and confirm the bracket size then go to your buddies shop and have him brake u out some new ones out of stainless
