project lucky seven - Page 54 - JeepForum.com
post #796 of 1565 Old 02-22-2012, 06:48 PM
1993BlackYJ
Originally Posted by twinstickd20 View Post
thanks Chad
Some day we just need to get together and go wheeling.... either here or there, maybe both!
1947 CJ-2A
1953 CJ-3B "Ray"
1957 CJ-3b "Jeep with no Name" Parts Donor
1971 CJ5 "Dorothy" 225 Dauntless V6
1993 Black YJ 4.0L, 5 speed, Posi-Loc, 35x12.50 MTZ, 4" Skyjacker lift, Ramsey 8500 Winch, OBA, Front Aussie Locked, 8.8 ARB Rear, 4.10s
My 93 Build Thread Over 700pics :
My 71 "Dorothy" Build Thread Lots of pics :
My 53 CJ-3B "Ray" Build:
Jesus Christ is my Lord and Savior
1993BlackYJ is offline
post #797 of 1565 Old 02-22-2012, 09:09 PM Thread Starter
twinstickd20
1979 CJ7
Yes we do, some day.
My Build Thread
twinstickd20 is offline
post #798 of 1565 Old 02-23-2012, 09:21 AM Thread Starter
twinstickd20
1979 CJ7
The other goodies are here.
My Build Thread
post #799 of 1565 Old 02-23-2012, 11:30 AM
MrBeast
1980 CJ7
Sweet
"He used to be a pretty nice feller, now he's a welder"
AMC 304 V8, NV4500, Dana 300, Dana 44, 9 inch, M.O.R.E. SRS, YJ tub.
AT3 US Navy 1999-2003
Cum catapultae proscriptae erunt tum soli proscript catapultas habebunt
(When catapults are outlawed, only outlaws will have catapults)
MrBeast is offline
post #800 of 1565 Old 02-24-2012, 07:52 PM
ardis8500
1976 CJ7
Hey man, it took me a few days to go thru the entire thread and I have to agree with everyone. Awesome jeep and your build/fab skills are exceptional. When I was building mine, I was torn between the of green and the sand tan / beige. As you can see, I went with the green. Mine is a 76 but I'm running 82 wt axles from a Scrambler. I also have the 258 (which I am paying close attention to the fuel injection install & results) running the MC2100 and the chevy HEI. I also have the T-18a tranny with the D20. My lift is from 6" rough country which I am about to pull one of the leaves out for a slight adjustment in height (lower), better ride and flex. I also have the YJ bars with the OR-Fab weld in kit (which I highly suggest). Anyway, again superb job on what you've done and going to do. I wish I had more $$ to do some of the stuff you've done. I just need to wheel mine more. BTW, do you ever make it down to Uwharrie in NC? I'd love to see it in person, in action.
1976 CJ-7 (resto-mod), YJ "family" cage, 6" YJ Springs, 35" BFG MT's, Warn 8274, 258, T-18a, D20, WTD30 & WTAMC20, 3.54 gears & locked F&R.
ardis8500 is offline
post #801 of 1565 Old 02-24-2012, 08:44 PM
MrBeast
1980 CJ7
Nice rig.
MrBeast is offline
post #802 of 1565 Old 02-24-2012, 09:13 PM Thread Starter
twinstickd20
1979 CJ7
Thank you, yours looks very nice, do you have a build thread? How do you like the t18? I hope to get started on the engine rebuild and upgrade soon it's just been kinda busy for me and my cousin so maybe I'll be able to get it to his shop soon and let you know how that turns out. As far as Uwharrie, I have only been able to wheel it a few times because of work and mechanical issues so the farthest I have made it is golden mountain in cookville (plan to be there again for the 2012 Dixie run).
My Build Thread
post #803 of 1565 Old 02-24-2012, 09:38 PM
ardis8500
1976 CJ7
I would love to come up to Golden Mountain. I see it on TV all the time but its a haul from down here (Charleston, SC).
Thanks but No, I don't have a build thread because it was so long ago and it took so long to do. I originally had the engine and drivetrain in a CJ-5 that had some rust issues, so I basically did a frame and body swap with this CJ-7 that I bought in pieces.
The T-18a was one of the best upgrades that I did. I still run my factory 3.54 gears and the T-18a is the only way that I can. I probably need 4.10's, but I'm unsure. Its almost like having a range box because the 2nd gear in the T-18a is still lower than the 1st gear in the T-150.
Be sure to get the torque arm mount with the T-18a if you can. If not you can fabricate one. It's just a beefier version of the T-150 arm. I didn't get one so I modified the one from the T-150. If you're still using the factory skid, the good thing is that you can still use it, but it slides back by one set of holes in your frame. Yes, you will need to modify the driveshafts.
post #804 of 1565 Old 02-24-2012, 09:53 PM Thread Starter
twinstickd20
1979 CJ7
I knew about the skid and the driveshafts but didn't really look at the mount, I think I have the torque arm mount but for sure. I may look into building a new flatter skid and redesign the mount anyways.
My Build Thread
post #805 of 1565 Old 02-24-2012, 09:55 PM Thread Starter
twinstickd20
1979 CJ7
All mounted and polished (for protection not bling) lol.
My Build Thread
post #806 of 1565 Old 02-24-2012, 10:02 PM
ardis8500
1976 CJ7
I'm thinking of doing the same thing. I have a guy in our club that is giving me an aftermarket skid that he doesn't need anymore and I hope to gain some clearance.
Very nice wheels.
post #807 of 1565 Old 02-25-2012, 02:47 AM
SinisterJeeps
1983 CJ7
twinstickd20 great build! Definitely one of my favorite CJs!
When you were running the stock XJ rear springs soa, how many inches of lift would you say that was for the rear compared to bone stock?
Forgive me if it was previously mentioned, I'm still working my way through every page.
Thank you!
SinisterJeeps is offline
post #808 of 1565 Old 02-25-2012, 10:14 AM Thread Starter
twinstickd20
1979 CJ7
Thank you!
Thanks, the factory xj springs settled to be flat under my jeep so I would guess that it would be the same as a soa cj on factory springs.
My Build Thread
post #809 of 1565 Old 02-25-2012, 05:37 PM Thread Starter
twinstickd20
1979 CJ7
I bolted the other two wheels on today, I had to grind down a spot on the brake caliper a little to bolt on the passenger front wheel. At full lock they touch the spring so wheel spacers are in the future plus I want to regain the inch I lost since the backspace on the old wheels was 2.5 and the new ones are 3.5. I took some pics with my gf's camera so I'll post them up tomorrow. But here is one for now.
My Build Thread
post #810 of 1565 Old 02-25-2012, 05:44 PM
nshefbuch
1982 CJ7
Love those rims. Looking great. Wider stance will feel more stable too being how tall you are
CJ7/SOA /5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt detroit/d44 ARB 4.10 High Steer
nshefbuch is offline
280zx hood vents , led parking lights , xj spring stretch
Hello, My '07 JK Project... Liquor Jeep Builds 132 08-03-2014 07:40 PM
The TJ Project GriffTatum Jeep Builds 17 08-11-2011 01:44 PM
yj project cage013 Jeep Builds 5 08-01-2011 11:40 AM
The Lucky Charm LuckyCharm4x4 Jeep Builds 4 07-29-2010 10:24 AM
"Lucky" My '53 Willys Pickup myascape Jeep Builds 3 01-10-2009 01:37 PM
