Project IOH - 79 CJ5 Refresh - Page 3 - JeepForum.com
post #31 of 255 Old 05-07-2012, 10:58 AM Thread Starter
2girlsAndaGuy
1979 CJ5
rocker panel patching
Patching sheetmetal is tough work, by far the toughest welding I've had to do so (although that's not saying to much since I've only been welding for a few months or so now. )
I managed to cut out the rot on the drivers side which included a bit of the floor and some of the support structure just behind the cut out. These aren't the prettiest patches in the world but I have confidence that with a little filler and sanding you won't even be able to see them.
So I got them marked about where I wanted to cut and went to it.
after the sheetmetal was gone, I saw more rust behild it that needed to go as well.
after everything was cleaned up with a flapper I started tacking this patch in. Again let me say this was really hard for me. Burning through this stuff is super easy to do. As you can see in the last photo in this sequence the inside welds haven't been cleaned up yet. Still a bit of work to do there but I got the majority of this patch finished.
David
2girlsAndaGuy is offline
post #32 of 255 Old 05-07-2012, 11:04 AM Thread Starter
2girlsAndaGuy
1979 CJ5
passanger side rocker patch
nothing earth shattering on this side either, had more rust at the floor here as well so needed to cut it out just as I did on the driver side. Made my patches using the old cut pieces as templates and started cleaning things up for welding.
again the inside of the tub isn't quite finished yet but after some grinding a bit more welding and some more grinding the inside should look fairly nice as well.
Overall I'm quite happy with the results of these patches. They are my first attempt at doing anything like this, and I feel that although not perfect by any means they will be quite serviceable after some filler work and sanding.
David
post #33 of 255 Old 05-07-2012, 12:03 PM
acgcoug
1979 CJ5
Looks good hawk.
I'm not sure if you are using a push or pull method when welding the sheet metal, but the push method is much easier in my opinion when working with sheet metal. You are able to see your weld puddle much easier when pushing. Also, remember to move around a lot with your welds to minimize excessive heat build up.
What size wire are you using? How about wire feed speed and amp/heat setting?
_________________________
Adam's 1979 CJ5 Frame-up build:
acgcoug is offline
post #34 of 255 Old 05-07-2012, 12:47 PM Thread Starter
2girlsAndaGuy
1979 CJ5
With that sheet metal I wasn't able to use any welding method other than tack...move...tack. Anything other than that and I would burn right through. There was no laying beads down on this stuff. I am running .023 wire with shielded gas, and had the wire speed set around 3 on my machine. Heat setting was at it's lowest. On the floor patches I was able to lay some beads cause I was using some thicker gauge material, but those side patches were just a cluster of tacks layed over each other.
David
post #35 of 255 Old 05-07-2012, 01:19 PM
acgcoug
1979 CJ5
Sounds good. You definitely have the right setup/settings.
I also found that with my tack...move...tack on my sheet metal, that my tacks came out a little better when my welding wire stuck out no more than a 1/4" from the gun tip. The arc tends to dance around less and you get a nice "eggs on a hot frying pan" sound (meaning a good tack).
acgcoug is offline
post #36 of 255 Old 05-07-2012, 01:31 PM Thread Starter
2girlsAndaGuy
1979 CJ5
I'm pretty sure I had it set up properly, I was just lacking in skill.
Here is the last of the body work that got tackled this weekend. The driverside rear corner had a nice size crack in it from who knows what, just another piece of damage to that corner from whatever the PO had hit years ago. So I spent some time shaping and beating on it. Once I was happy with it's shape it got flapped and welded up. I still have a bit of grinding to do on this one as well, but my grinding stone was on its last leg and by this point I was to lazy to put another one on.
David
post #37 of 255 Old 05-07-2012, 06:53 PM
Skerr
Hey LDH, that's looking good. Speaking for myself, as a beginner welder, one of the toughest things I did was grind down my welds. It seemed crazy to lay down a weld only to grind it off, so I had a tendency to leave some of the weld on top of the surface. It looks to me like you have some weld still remaining also. Don't be shy about grinding it all the way down. If you got a good tack then it is joined inside the seam. If you didn't get a good tack, you want to know about it now, and not in 8 or 9 months when a rust bubble pops up. You may have already addressed it. By the same token, the sheet metal is already thin, so be careful when you lay on the grinder.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #38 of 255 Old 05-07-2012, 09:02 PM Thread Starter
2girlsAndaGuy
1979 CJ5
You talking about the welds on the frame or tub skerr? I don't plan to grind down the crossmember but all the sheet metal will get some more attention before I'm done with it. Thanks for the comment, it's funny that you say that because whenever I lay down a nice looking bead I'm the same way, I like to look at it not grind it off. Lol I've been struggling with just that on my fenders. Can't decide if I want to keep the welds or grind the tops smooth before paint. Thanks again for pointing me toward Jason, that worked out really well for me. Can't believe how quickly he got that crossmember to me!
David
post #39 of 255 Old 05-11-2012, 10:35 AM Thread Starter
2girlsAndaGuy
1979 CJ5
Happy Friday
Hello and Happy friday to everyone! Hope everyone is going to have a wonderful mothersday weekend. I have the day off and sadly won't be getting much if any jeep work done today or this weekend for that matter. We have a large mothersday bbq at our house on saturday and I've got lots to get ready before tommorow.
Just incase some of you are a bit confused right now, keith made a name change for me. Here is the thread explaining it...
http://www.jeepforum.com/forum/f8/ju...ds-up-1367708/
Hope to have an update for you all later this weekend!
David
post #40 of 255 Old 05-14-2012, 10:59 AM Thread Starter
2girlsAndaGuy
1979 CJ5
well didn't get a chance to work on the jeep at all this weekend, but I did manage to haul 4 yards of gravel and build some stairs for my deck. The bbq was a success and I managed to get the front of the house looking somewhat decent before anyone showed up. Was a long weekend working on the house, but it has been neglected for a while now.
David
post #41 of 255 Old 05-14-2012, 01:40 PM
jakeryii
1967 CJ5
thats a sweet lookin patio but with the deadmans it wouldn't pass code where i live
94 ZJ 4.0, np 249 on 31x10.50s no lift
jakeryii is offline
post #42 of 255 Old 05-14-2012, 09:24 PM Thread Starter
2girlsAndaGuy
1979 CJ5
Thanks jake I'm happy with how it turned out, now I just need to enclose the breezeway. The nice thing about my county is that decks not exceeding 4ft in height don't require a permit.
David
post #43 of 255 Old 05-15-2012, 05:49 PM
Griffen24
1979 CJ5
Following your tread from here on out. I have a 79 CJ5 that I'm trying to build up the courage to do some body work on. It have the exact same rot on the fenders/floors that you had. Just wishing that I has some welding experience. Looks like I'll have to bring someone in for that part. Anywho, I can't wait to see how yours comes back together.
Griffen24 is offline
post #44 of 255 Old 05-21-2012, 11:43 AM Thread Starter
2girlsAndaGuy
1979 CJ5
good luck on your project griffen, won't know if you can't do the work until you at least try!
David
post #45 of 255 Old 05-21-2012, 11:48 AM Thread Starter
2girlsAndaGuy
1979 CJ5
Ok so another weekend down and a few more items off the checklist. I got all new hoses for the fuel tank as well as upper and lower radiator hoses. After our run into town we started tearing into the tank a bit, got it removed from the skid and it looks like I'll be needing new straps. Once we got all the gas drained out of the tank we taped up the holes and pressure washed it. Haven't decided what I'm going to do with it now however, anyone got any ideas on paint choice for the tank?
David
my bbc cj project kw89425 Jeep CJ Forum 259 09-21-2013 06:49 PM
My new Project.... motoman45_00 Jeep CJ Forum 6 06-05-2011 04:04 PM
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 12:38 PM
Please Refresh my Memory and tell me how this mounts! CJman77 Jeep CJ Forum 11 01-09-2009 04:53 AM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 06:53 AM
