Project IOH - 79 CJ5 Refresh - Page 16 - JeepForum.com
post #226 of 255 Old 07-15-2013, 09:43 AM Thread Starter
2girlsAndaGuy
1979 CJ5
after recovering from rainier and adams the last two weeks here is the progress I've made on the jeep.
rear tail lights and markers are all wired up and functional. Replaced the flashers with electronic and now the LED's blink as they should. However I'm having issues with the front blinkers, issues being they dont work.
Name:  marker lights.jpg
Name:  marker lights side.jpg
Name:  backup lights.jpg
Name:  brake lights.jpg
3pt seat belts are installed.
Name:  seat belts.jpg
Name:  seat belts1.jpg
David
2girlsAndaGuy is offline
post #227 of 255 Old 07-15-2013, 09:49 AM Thread Starter
2girlsAndaGuy
1979 CJ5
I've managed a few small treks out and about with the jeep since I got her running but my dog Ollie had her first ride in the jeep this weekend, the wife and I though it was a pretty monumental moment.
thus the overwhelming quantity of pictures just backing out of the driveway.
Name:  Ollie first ride1.jpg
Name:  Ollie first ride3.jpg
Name:  Ollie first ride.jpg
Name:  Ollie first ride2.jpg
we have a small field across the road from our house, Ollie and I drove around it for a few minutes and the wife snapped these shots as we were dinking around on a small gravel pile.
Name:  poser shots1.jpg
Name:  poser shots2.jpg
And here is just one last picture for no good reason other than I though it looked neat.
Name:  poser shots3.jpg
David
post #228 of 255 Old 07-15-2013, 09:40 PM
Skerr
Awesome, Man... just awesome. We climbed over a similar gravel pile when we got Clay's Jeep out of the shop! Our version of rock climbing! Proud of you, Bud. The Jeep looks great. The mountain pics are fabulous. Glad you didn't fall into a ravine!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #229 of 255 Old 07-15-2013, 10:07 PM Thread Starter
2girlsAndaGuy
1979 CJ5
Hey, gravel is a form of rock yes.
David
post #230 of 255 Old 07-18-2013, 03:56 PM Thread Starter
2girlsAndaGuy
1979 CJ5
one step closer to being full road worthy, gonna go and sign papers tonight with my insurance agent. Covered for $15,000.
David
post #231 of 255 Old 07-24-2013, 09:01 AM Thread Starter
2girlsAndaGuy
1979 CJ5
well ran into a bit of a snag last night, was working in the engine bay and spotted a chalky white residue all over my exhaust manifold. This just showed up, I put 50 miles on the engine this weekend and a few issues have reared their ugly head since then. This one appears to be the symptoms of an extreamly lean running engine.
This is the first real drive that was put on the engine since I've replaced both the intake and exhaust manifolds, could this be as simple as a vacuum leak somewhere? Any idea's on what to look at first?
David
post #232 of 255 Old 07-24-2013, 11:42 AM Thread Starter
2girlsAndaGuy
1979 CJ5
ok after a discussion with our shop mechanic at my work, he said that most likely what I am seeing on my manifold is burnt off paint from when I painted it black. He said that those high temp paints are pretty much worthless for manifolds and that the white residue is basically an ash left from what burnt off.
I will attempt to scrub off the residue and see what is underneath it.
David
post #233 of 255 Old 07-26-2013, 06:19 AM
Skerr
Yeah, yeah... I agree. Freaked me out when I fired Clay's and smoke started rolling out from under the hood!! Manifold is under the residue!!
DRIVE...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #234 of 255 Old 07-29-2013, 10:18 AM Thread Starter
2girlsAndaGuy
1979 CJ5
well I had a pretty rough weekend as far as the jeep is concerned this weekend. I was looking forward all week to finally installing a twin stick kit on my sloppy Dana 20 and having a smooth shifting case. Unfortunately after installing the new kit I cannot get the right stick to shift at all. Appears to be completely seased stuck. I can shift the rear wheel linkage in between high low and neutral, but no matter what I do I cannot shift the front wheel linkage at all it is completely stuck. Not sure what to think or even try with it at this point....
Looks like I'm going to have to put the jeep back out of commission right after I finally got it running again. Me = frustrated.
David
post #235 of 255 Old 07-29-2013, 11:11 AM
twinstickd20
1979 CJ7
So you can't put the rear in low and then put the front in low too? The interlock pill inside the transfer case will not allow you to shift it separately, you have to engage the rear first then the front unless you remove the interlock.
My Build Thread
twinstickd20 is offline
post #236 of 255 Old 07-29-2013, 12:03 PM Thread Starter
2girlsAndaGuy
1979 CJ5
tried it with rear in low high and neutral, couldn't get the front to move in any case. The shaft is all the way against the case at this point.
David
post #237 of 255 Old 07-29-2013, 12:06 PM
twinstickd20
1979 CJ7
That's strange, did you move the jeep and try again?
My Build Thread
post #238 of 255 Old 07-29-2013, 12:56 PM Thread Starter
2girlsAndaGuy
1979 CJ5
ya, I had it in first and reverse multiple times rocking back and forth trying to move that stick. Any more force and I would have bent the darn thing.
David
post #239 of 255 Old 07-29-2013, 02:08 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Did it work before you put on the twin sticks? or haven't you tried it in a long time.
Mine would lock up on me all the time, the more I use it the easier it got..
Also, be sure to rotate your fuel filter the right way...
John Strenk is offline
post #240 of 255 Old 07-29-2013, 02:42 PM Thread Starter
2girlsAndaGuy
1979 CJ5
haven't used it in a long time... 2+ years. The linkage was so sloppy with the old setup that I assumed that was the issue. I reefed on that shift rail pretty hard... much more and I worried things would start breaking.
Check on the fuel filter... always get that orientation screwed up.
I don't even want to talk about my fuel gauge at this point... more than done with that one.
All new wires including grounds straight to the battery and I still get a drop in ohm's at the gauge. Gonna call autometer and give them hell till they send me a new gauge.
David
my bbc cj project kw89425 Jeep CJ Forum 259 09-21-2013 05:49 PM
My new Project.... motoman45_00 Jeep CJ Forum 6 06-05-2011 03:04 PM
Project Tub Swap... then Project Moab certifiablejeep Jeep CJ Forum 9 08-04-2009 11:38 AM
Please Refresh my Memory and tell me how this mounts! CJman77 Jeep CJ Forum 11 01-09-2009 03:53 AM
Project Reassembly has inspired my project WHAT THE HECK WAS I THINKING jcooley7 Jeep CJ Forum 5 05-28-2008 05:53 AM
