project flatty...follow along - JeepForum.com
post #1 of 9 Old 05-15-2007, 06:28 PM Thread Starter
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
well came home sick today from work...cough cough...and was looking at the parts cj I have and decided to start a flat fender project..It will be an ongoing project,so feel free to critique or ask any questions...
I like the flatty look but dont care for the cut off wheel and leave it look..for a few reasons..
1..lets face it those edges are damn sharp..I wouldnt want anyone including myslf getting cut on the trail cuz of those fenders
2..no support..In the winter if I'm stuck I usaully climb out the window along the hood and onto a fender to hook up a winch or strap..
3..they just plain look better to me..
parts and tools used so far
1/2 inch thick walled conduit..bends easily and welds nice
handy dandy hand conduit bender..
4 or 5 inch cut off wheels on an angle grinder..be sure to use eye protection!!!!
projected tools and material
welder
1'' by 3/16th x 2foot flat stock
pipe notcher..can also notch or birdmouth pipe with a grinder
angle grinder
I have been studying PSC and a few other bolt on flat fenders for Ideas
first I basicly sat back and stared at the fender for a while and kinda got an idea of the lines I wanted..I drew lines with dry erase marker at the cuts I wanted...I was pretty happy with the firts attempt,but the good thing about dry erase markers,they just wipe off...
the cut off wheel makes short order of the sheetmetal,but DO NOT bind the blade or it will come apart and take and eye out or worse...
the bending went pretty easy..I did them by eye and lucked out without ending up with a scrap peice..There are plenty of formulas to get the proper radius's and bends,but I dont have time for them..At least not for these...If it were a cage,with 6 dollar a foot DOM,thats a different story..
I still need to trim back the fender to fit the pipe a lil better,as most of the edges are jagged...
heres a few pics of what I ended up with within an hour..and what look I'm going for..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #2 of 9 Old 05-15-2007, 06:46 PM
c17load83
Are you gonna stick with the duct tape or throw some welds in there? J/k let us know how it turns out. Looks fun so far.
c17load83 is offline
post #3 of 9 Old 05-15-2007, 06:47 PM
Lostj
Lostj's Avatar
Cool project.
00'TJ
74'CJ5 For Sale
Lostj is offline
post #4 of 9 Old 05-15-2007, 07:05 PM Thread Starter
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
lol..if I can find the right color The tape will do...
:hahaha: yj
post #5 of 9 Old 05-15-2007, 07:36 PM
bdmonist
WTF is that?
bdmonist's Avatar
Looks good - From a strength stand point, wouldn't pipe be stronger than conduit? Not as easy to bend, but in the long run...???
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #6 of 9 Old 05-15-2007, 07:41 PM Thread Starter
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
your absolutly correct...If I was a rock hound I would certainly look into a 1''and1/4
hrew pipe..I still may go that route...just using the conduit as a jig to bend the other to...
:hahaha: yj
post #7 of 9 Old 05-21-2007, 08:37 PM Thread Starter
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
getting a lil closer..bouncing between these and tube doors..
ended up keeping the 1/2 inch pipe..seems pretty strong for what they are...deffinately not rock proof,but dought i'll see rocks with this jeep..
After cutting the opening the rear if the wheelwell was opened up,after a push and a bunch of welds it was in place.I deffinately will do a few things different on the passenger side..This ones going to need a lil bit of plastic to get it smooth on the side
:hahaha: yj
post #8 of 9 Old 05-21-2007, 08:46 PM
high51977
ever worked with lead filler? it is just as easy to use as bondo but it doesn't crack and flake off.
Play by the rules you're gonna miss all the fun
high51977 is offline
post #9 of 9 Old 05-21-2007, 09:07 PM Thread Starter
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
accually yes..I took a few years of auto body and used it alot on a few old cars of mine...Its not that bad,though it looks in the crappy pics to warrant lead...maybe an 1/8,if that..
:hahaha: yj
best mastercylinder for 48 flatty vswv8 Jeep CJ Forum 2 06-24-2008 07:02 PM
Cheep and easy snorkle for my Flatty ronprice Jeep CJ Forum 8 08-27-2007 10:28 AM
??'s about a flatty purchase Mr.Crowley Jeep CJ Forum 8 01-22-2007 09:19 PM
Flatty build ?... Jeepfreak81 Jeep CJ Forum 8 08-23-2006 06:18 AM
CJ5 Still not running (follow up to previous msg) fickesd Jeep CJ Forum 1 04-29-2002 08:36 AM
