Project "Envy" - Page 6 - JeepForum.com
post #76 of 551 Old 10-21-2010, 06:43 PM Thread Starter
bbc
Originally Posted by Deadman 94 xj View Post
Axle looks good. You might be better off going with a Full width 9" and cutting it down. The early bronco housings are weaker and small bearing. Just incase you haven't covered that in your research already.
I'm going with a currie 9+ heavy duty housing for a early bronco
(got it covered)
but if one where to go with a original Early bronco 9 inch, the 76'-77' are heavy duty housings and have the big bearing ends.
bbc is offline
post #77 of 551 Old 10-21-2010, 06:52 PM
Deadman 94 xj
1977 CJ5
I doubled checked. You're right about the 76-77.
77 CJ5. 304, t-150, D20
Deadman 94 xj is offline
post #78 of 551 Old 10-22-2010, 05:44 PM Thread Starter
bbc
most of the medium duty 9's have big bearing torino ends as well.
bbc is offline
post #79 of 551 Old 10-22-2010, 09:11 PM
Deadman 94 xj
1977 CJ5
Based on what I remember from a long long time ago, early bronco 9" had weak housings (most 9" axle require at least a truss anyway which is probably why you're going after market) and small bearing ends. I don't remember the years of which had what, I just know it was the majority. Regardless, my reason for posting was to offer some insight incase there might have been something you overlooked, which is usually the point of these threads. Not to get into an "I know more than you about 9" axles" post swap.
Good luck with your build. Looks good so far.
post #80 of 551 Old 10-22-2010, 10:15 PM
83vert
1982 CJ7
That axle does look sexyyyyyyyyy, DAMM.
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #81 of 551 Old 11-11-2010, 03:39 PM
Jim1611
Jim1611's Avatar
You like the rest of us and too busy to get any work done on the Jeep? Just thought I'd check on you.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is online now
post #82 of 551 Old 11-12-2010, 03:42 AM Thread Starter
bbc
Yes, work and my 2 small boys take up most of my time.
just waiting patiently for you to re engineer that rear shackle hanger I sent you for the 1 -1/4 bushing. After that I will call up alcan and order some springs.
I guess the hardest part of all this is i keep second guessing myself and changing my mind on what i want to do with this build.
Now, I'm maybe thinking that I should have set that front axle up for SOA instead of SUA.
I'm sure SUA will be just fine for what i want.
bbc is offline
post #83 of 551 Old 11-12-2010, 06:45 AM
Jim1611
Jim1611's Avatar
I do allot of that second guessing too. I have just convinced myself to go ahead and do what I want. Then if it doesn't suit me I'll change it later.
PM sent on the hangers.
My build thread
post #84 of 551 Old 11-12-2010, 10:39 PM
78CJFIVE
1978 CJ5
hey where'd you get the new body mount from? Not seeing them on Quadratech anymore..
78CJFIVE is offline
post #85 of 551 Old 11-12-2010, 11:16 PM Thread Starter
bbc
bbc is offline
post #86 of 551 Old 11-18-2010, 03:32 PM Thread Starter
bbc
darn it!
I think I made up my mind to change and re work the front axle for a SOA lift.
it's all painted and set up for SUA and then i go and change my mind.
help!
re assure me that i am doing the right thing by changing it to SOA
or give me a reason to keep it SUA.
bbc is offline
post #87 of 551 Old 12-03-2010, 04:08 PM Thread Starter
bbc
Well, seems nobody talked me out of it!
the dirty deed is done-
I ordered my springs for a spring over today
the RE 1.5 SOA YJ springs.
I think I have lost my mind
bbc is offline
post #88 of 551 Old 12-03-2010, 04:11 PM
Coiz
1979 CJ7
Sweet! Take lots of pictures.
Mike
Coiz is offline
post #89 of 551 Old 12-06-2010, 10:08 PM Thread Starter
bbc
lets just take a look back and some time to reflect on what used to be.
bbc is offline
post #90 of 551 Old 12-18-2010, 01:22 PM Thread Starter
bbc
The RE 1.5" SOA springs have arrived, along with some new m.o.r.e. greasable shackles and bushings.
Now I just have to drill the 1.5" hole in my frame for the front shackle to go through for the SRS.
I will try and get this done this weekend and get some pictures up.
I also have all the spring perches and u-bolts i need to mount my axles.
All I need now is some wheels and tires to get this thing in to a roller.
I figure i will then put the body back on to get an idea of how this thing will sit.
And then make some decisions.
bbc is offline
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 03:57 PM
Project "Vote Utilitarian" Floridazed Jeep CJ Forum 301 01-18-2015 09:25 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
"Don't buy someone's project in pieces; Buy a runner that is broken." - Good advise? JeepIdolator Jeep CJ Forum 15 11-09-2007 09:50 AM
