Project "Envy" - Page 5 - JeepForum.com
post #61 of 551 Old 07-13-2010, 11:34 PM Thread Starter
bbc
did not outboard, thats why i narrowed the 44 to fit the cj frame
bbc is offline
post #62 of 551 Old 07-14-2010, 01:58 AM
jeffyjensen
1980 CJ5
looks good. very nice frame repair. did you coat the inside of the frame?
1980 CJ-5, Ford 351w, in restoration, kind of
jeffyjensen is offline
post #63 of 551 Old 07-14-2010, 06:21 PM Thread Starter
bbc
Thanks. the inside got sprayed the best i could
bbc is offline
post #64 of 551 Old 08-03-2010, 08:41 AM
Kman1983
1983 CJ5
bbc did you start with a narrow track Waggy 44 or a widetrack? I have a Waggy 44 but its a widetrack.
Rolled Red Jeep Club Member #258
'83 CJ5, 4.0 MPFI swap, T18/D20, CenterForce II clutch, Dana44/30(73 CJ5) with 3.73's,'79 knuckles and 11" discs, sagged 4" lift, 2" BL, 34x9.50x15 Super Swamper Pizza Cutters
My wifes website The Vermont JeepGirl
"Good Girls and Dirty Jeeps" a song by Opal Justice
Kman1983 is offline
post #65 of 551 Old 08-03-2010, 09:13 PM
jlong620
First off - this is a kick butt thread. Secondly, I think he probably started with the narrow waggy.
But, you can use a wide waggy IF you want to go about 4" total wider. Same process but the end result will be an extra 2" per side. This is my best understanding so far. I have a 74 J10 axle which is a wide axle that I may be hacking shortly.
The big questions for me come down to putting the steering back together and if I have to move the steering box etc...
jlong620 is offline
post #66 of 551 Old 08-07-2010, 10:22 PM Thread Starter
bbc
It was a narrow track waggy 44, should put me at 58" wms-wms with the ford 5x5.5 hubs & rotors swap.
I am going to pair that with the early bronco 9" rear that is 58" as well.
bbc is offline
post #67 of 551 Old 08-07-2010, 10:27 PM Thread Starter
bbc
I am moving my steering box forward with a m.o.r.e HD bracket, but thats also due to me doing a shackle reversal at the same time.
I got the 44 all painted up and I am waiting on parts to put it back together.
I sent the right side flat top knuckle to parts mike to be machined and drilled for high steer.
I also sent the long side shaft off to moser to be cut down 4" and replined.
got some small bearing spindles off ebay that i am waiting for and just have to gather seals and bearings.
hurry up and wait is the name of the game now.
bbc is offline
post #68 of 551 Old 08-10-2010, 09:25 PM
jlong620
That sounds cool. Are you using the jeep drag link and such or something else?
I cant make my mind up if I should do the crossover steer or high steer or use the J10 setup.....
jlong620 is offline
post #69 of 551 Old 08-11-2010, 12:25 PM
Kman1983
1983 CJ5
As I recall my wide track Waggy 44 measured 65" WMS-WMS when we put a tape on it.
Kman1983 is offline
post #70 of 551 Old 08-11-2010, 07:10 PM Thread Starter
bbc
Here would be the info, for using the WIDE TRACK D44 - Lots of good info!!!!!!
Don't Use a Wagoneer Front Axle - Jeep Scrambler Forums & Discussions
my drag link will be high steer, using the flat top knuckle
http://www.partsmike.com/store/store.php?crn=219&rn=1377&action=show_detail
and i will get custom length tie rod tubes
http://www.currieenterprises.com/cestore/Product569.aspx?id=1161
On another note,
I got my long side axle shaft back from moser today!!!
and will be picking up a new carrier for the new 4.56 gears this weekend.
still waiting for the knuckle to get back..
bbc is offline
post #71 of 551 Old 09-09-2010, 11:14 PM Thread Starter
bbc
This D44 build has taken some time, I pretty much have all parts, seals, 4.56 ring and pinion, and bearings now.
I have now decided, that I only want to build this axle once.
So, instead of just throwing in the new gears in a open carrier. I
Think I will wait and see if I can find a detroit truetrac for a good deal for it.
But, Damn guy's! this axle is looking Sexy!!!!
Every thing all painted up!!
I will get some pics of it up tomorrow.
It seems the final width of it ended up to be 57 5/8 " WMS - WMS
Real close to the 58" rear Early Bronco 9" thats going to be build next.
going with a
-currie 9+ heavy duty housing
-moser shafts
-True HI9 Center
-Disk brake conversion.
Then we will be ordering up some Alcan custom Springs.
And see if we can't get this into a roller.
Piece Fella's, Take care, and Jeep on!!!
bbc is offline
post #72 of 551 Old 10-21-2010, 04:56 PM
Jim1611
Jim1611's Avatar
Subscribed.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #73 of 551 Old 10-21-2010, 07:26 PM Thread Starter
bbc
Pictures of the long awaited waggy 44 front all painted.
And the custom Axle cart i threw together to wheel this thing around.
bbc is offline
post #74 of 551 Old 10-21-2010, 07:27 PM Thread Starter
bbc
more
bbc is offline
post #75 of 551 Old 10-21-2010, 07:36 PM
Deadman 94 xj
1977 CJ5
Axle looks good. You might be better off going with a Full width 9" and cutting it down. The early bronco housings are weaker and small bearing. Just incase you haven't covered that in your research already.
77 CJ5. 304, t-150, D20
Deadman 94 xj is offline
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 04:57 PM
Project "Vote Utilitarian" Floridazed Jeep CJ Forum 301 01-18-2015 10:25 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 08:02 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 07:26 PM
"Don't buy someone's project in pieces; Buy a runner that is broken." - Good advise? JeepIdolator Jeep CJ Forum 15 11-09-2007 10:50 AM
