Project "Envy" - Page 4 - JeepForum.com
post #46 of 551 Old 07-10-2010, 07:46 PM Thread Starter
bbc
I am doing this all on the back of my truck to show that you dont
need a fancy fab shop to do this.
Only tools I have used are -
1. BFH is a must
2. sawzall or Reciprocating Saw
3. angle grinder with cutoff disk and grinding disk
4. chisel
5. piece of angle iron
6. a sharp scribing tool
7. tape measure
8. welder - if you dont have one, then you can bring the axle some place to have the inner C, spring pad, and shock mount put back on.
but at least you did most if not all the work yourself saving a ton of money.
bbc is offline
post #47 of 551 Old 07-10-2010, 08:51 PM
Skerr
Thanks for taking the time to post the pics and explain. This is great info.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #48 of 551 Old 07-11-2010, 12:54 PM Thread Starter
bbc
Now that we have the spring pad and shock mount removed.
we now take and make a center line on both spring pads.
bbc is offline
post #49 of 551 Old 07-11-2010, 12:57 PM Thread Starter
bbc
set the removed spring pad on the axle, using are reference marks.
measure from center of each spring pad and set the removed pad centered at 27.5"
bbc is offline
post #50 of 551 Old 07-11-2010, 12:59 PM Thread Starter
bbc
now measure from the short side inner C to the center of the cast in spring pad.
its about 5 5/8"
bbc is offline
post #51 of 551 Old 07-11-2010, 01:01 PM Thread Starter
bbc
now, on the long side with our spring pads centered at 27.5
we can measure from the long side pad out 5 5/8"
and don't forget to add + 1" for the tube that sits into the inner C
So, - 6 5/8 is where we will cut
bbc is offline
post #52 of 551 Old 07-11-2010, 01:06 PM
geochaf1
geochaf1's Avatar
1985 CJ8
very nice work!
geochaf1 is offline
post #53 of 551 Old 07-11-2010, 01:06 PM Thread Starter
bbc
Now we make the long awaited cut!
bbc is offline
post #54 of 551 Old 07-11-2010, 01:10 PM Thread Starter
bbc
after the cut, grind the end clean and put a small bevel or taper on it, so it can get started into the inner C.
remove rust and crap from the end of the axle tube and line up our reference lines.
Use the BFH and pound the inner C to it's new home.
bbc is offline
post #55 of 551 Old 07-11-2010, 01:15 PM Thread Starter
bbc
All that is left is to weld the inner C, spring pad, and shock mount back on.
then send the axle shaft out to get cut and re splined.
sand blast the new axle and shoot some paint.
Done!!!!!
Next - I will get into the early ford bronco 9" rear
both of these will be fitted with new 4.56 gears
and some sort of lockers
bbc is offline
post #56 of 551 Old 07-11-2010, 01:29 PM
Skerr
I can do this! And you made it look easy. Thanks a million. Thread saved!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #57 of 551 Old 07-13-2010, 05:20 PM Thread Starter
bbc
Waiting for the 44 parts to come, But I got the M.O.R.E SRS kit in.
Along with their HD steering box mount today.
And here is some pictures of the frame all done with a little dust on it from sitting all winter.
bbc is offline
post #58 of 551 Old 07-13-2010, 05:22 PM Thread Starter
bbc
Also, here is the 9" rear from the Early bronco I will be working on next
bbc is offline
post #59 of 551 Old 07-13-2010, 05:52 PM
243
1978 FSJ Cherokee
BBC you made it look very easy, have you narrowed an axle before?
Thanks for posting the modification
Dave's 78 Build
243 is offline
post #60 of 551 Old 07-13-2010, 09:27 PM
Deadman 94 xj
1977 CJ5
Great write up and nice attention to detail! Question for you, and sorry if I missed it, are you or did you outboard the springs for this?
What do you think your turning radius will be like? If you outboarded, will the tires rub the springs at full lock?
Thanks!
77 CJ5. 304, t-150, D20
Deadman 94 xj is offline
BUILD THREAD: Project "Ghetto Fabulous" motiv8ya Jeep CJ Forum 804 06-11-2017 03:57 PM
Project "Vote Utilitarian" Floridazed Jeep CJ Forum 301 01-18-2015 09:25 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
"Don't buy someone's project in pieces; Buy a runner that is broken." - Good advise? JeepIdolator Jeep CJ Forum 15 11-09-2007 09:50 AM
